Mike_Eddleman 70 #1 Posted November 22, 2015 I guess the guy I got my tractor from has lost the PTO shaft, the part that hooks to the tractor. I found some parts and am thinking about trying to make one. Any thoughts if this will work? I plan on taking the quick connect off the tractor that is pinned to the pto shaft, weld it to the end of the knuckle that I have and then cut off the other end of the shaft that is a 1" square and weld a 3/4 inch square by 13" that is needed to fit the pto to my bush hog and tiller then all I should have to do Is pin it to the PTO shaft on the tractor. other than that I really don't know what to do, I haven't been able to find the 15 tooth PTO anywhere Share this post Link to post Share on other sites
rmaynard 15,426 #2 Posted November 22, 2015 What model tractor are we talking about? Share this post Link to post Share on other sites
oldredrider 2,548 #3 Posted November 23, 2015 There is one for sale on CL in Richmond, Va. Share this post Link to post Share on other sites
Mike_Eddleman 70 #4 Posted November 23, 2015 sorry it's a 1973 d 180 the one on CL in Richmond is the shaft that goes in the tractor it's self I need the part that goes from that shaft to the shaft on the bush hog Share this post Link to post Share on other sites
953 nut 55,049 #5 Posted November 23, 2015 Have you checked with agrisupply.com on line, they have quite a variety of PTO components to choose from. Share this post Link to post Share on other sites
