rjg854
I'm looking for you wonderful folks here at :rs:to critic this new purchase.  Tell me what you think it may need or what possibilities there are for it.  I'm open to all suggestions and information.  It seems to be in good shape, and mostly complete.
Edited by ranger13148
grammar
  • Like 8
AMC RULES
Awesome :wh: survivor...    :handgestures-thumbupright:
heres hoping you don't restore it.
  • Like 5
rjg854
I'm probably going to leave it as it is.  But the drive belt guard is all rust, and no paint.  What could I do with that?
AMC RULES
Knock the rust down with a very light sanding...  :confusion-shrug:
then give it an oil bath, while you look for one in better condition.
You're going to  need a push button starter switch for the hole in the trans tunnel too.
s-l1600.jpgNot sure if this one is the same one for your application, but I'll send you the link.
Edited by AMC RULES
squonk
Ya got your tractor. Now whatca gonna do for fun? :)
squonk
I just noticed the rear tires. General Garden Tractor SS's. I remember that brand on our 64 604 when I was a kid.
rjg854
Well to start with, working on the tractor to get it running nice.  Got some carburetor issues right now.  I think someone might have installed the tierods wrong?  The rod that holds the hitch on has been sawed off on both ends so I does and can't put a hitch on it. etc
WheelHorse79
Your tank stand is interesting.  I believe all 854s were key start only with no starter button (or hole).  Mine was that way when I bought it.  However, my tank stand had been ripped open around the gear shift lever, so I bought a '63 753 tank stand which had the extra starter hole. So, if your tank stand is original, I'm surprised that it has the extra starter hole.  Maybe your tractor is an early production model using the previous year tank stand?
squonk
You can get a new switch just like the one Craig posted at Napa
rjg854
Think maybe some one might have cut the hole the key switch is in now?  Seems odd the hole is in part of the decal.
Terry M
My original, unrestored 854 has the empty push button holes with key start and is an early production 854 as per the serial # ....just saying:)
Edited by Terry M
Brian01
Great looking Tractor!
Oh and as far as the rusty belt Guard.  Get some CLR and a scotchbrite pad, the CLR will take most of the rust away n probably get some of the factory paint, shining through
Edited by Brian01
rjg854
I'll give that a try Brian, thanks for the suggestion ;)
is your key a fat square key?
Terry M
No, just regular Cole hersey key......Like a dummy, I have no pic of the key in the hole to show you.IMG_2684.thumb.JPG.131532880b6539921c2b5IMG_2683.thumb.JPG.fdc8da0c7df89a2f21d1aIMG_2685.thumb.JPG.ad42a2ea63d96c9c8445a
rjg854
I'll get a picture of my key and post it tomorrow.
Racinbob
That's definitely a dandy. The 854's used a key switch and not a push button. The key switch did bear the full starter current though so you'd need to get the appropriate one. The ones with the push button starter were undoubtedly installed because they didn't have the proper key switch to handle the current. They could have installed a solenoid. No harm done. The tie rods are on wrong. They must have connected them from the backside on the steering shaft plate. Should be from the front with the nut on the back. They should connect to the spindles from below with the nut on the top. All simple fixes though. :)
Edited by Racinbob
JERSEYHAWG /  Glenn
I think its great, looks complete, nice and straight.
Glenn
Shynon
:text-yeahthat:
Terry M
Ranger, keep that belt guard!!!
Brian01
I agree Terry, CLR and a good scrubbing followed possibly by some WD40 and she'll look great
jackhammer
Good looking tractor
Nice find
rjg854
here are some pictures of the key I have for the tractor
RedRanger
That's factory?????
  • Similar Content
    • dlashb40
      By dlashb40
      As a retired 61-year-old who inherited 4 of my Grandfather's Wheel Horse tractors, I found a valuable resource in this forum. Here, I connected with Bob Parks (Racinbob), who at the time lived nearby and kindly agreed to help me identify all of them. I ended up keeping the 1964 Model 854 and sold the others. The 854 is a solid, primarily original tractor, and I've been using it since I was 6-years-old. I also had the RM-364 mower deck attachment, which had not been on the tractor for many years. Once again, this forum proved its worth as I could identify and obtain some attachment parts that I was missing. Last week, after some adjustments, I put the mower deck to use and mowed nearly an acre of grass without any issues. The sense of accomplishment in identifying and restoring the equipment was truly inspiring, and I felt like I was a kid again.
      As someone who doesn't consider themselves 'mechanically inclined,' I've grown and learned much through this project. I want to express my heartfelt thanks to all of those who guided me and showed me that with the right support, even the most daunting tasks can be tackled.
    • Bodean
      By Bodean
      In search of bottom plate for 854 two pieces tank mine is cracked will take whole tank if one is available i have a replacement gasket already thanks
    • Bodean
      By Bodean
      Slow but sure turning the corner get big red back together waiting on transmission seals
    • rustyedge1
      By rustyedge1
      These belts have been hanging in my garage since last used I believe there off a 754 I used to have. Bought them new and didn't use much.
      Don't know why I took them off. Some fraying on top in a few places from use, also don't know why but selling as is and photo'd. 20.00 shipped if you can use them.
      PM for PayPal info or questions. 16" ID approx.
    • Jennifer
      By Jennifer
      Okay friends husband and I brought home another mutilated mutation that I felt sorry for and wanted to fix….  Questions will it run??  Lol… what model for sure?  So I believe it’s an 854 and would like feed back to confirm..  lots of stuff coming off… has the k181s tag on the engine!  Two piece gas tank!  So if my friends on here would agree or disagree I would be able to see how much I have been learning over the years!
