mikehusky455
whats it look like besides a mix of two different kinds.
mikehusky455
mikehusky455
just forward and reverse besides neutral has 1 1/4 inch axle,couple inner chains inside.,would like to make a little slower,and no room to put bigger pulley on back cause its already close to my leg,with little engine even on idle gets a bit tricky in woods.
CasualObserver
Could you get a few more clearer pictures? Can't say as I've ever seen a model with that kind of shrouding under the seat.  I'd appreciate seeing a few more pictures from all sides.  Thanks!
Wishin4a416
Does it say Mahindra on the hood backwards
mikehusky455
well its put on there its normal I took pic with laptop so puts it backwards,the previous owner put mihindra turbo sticker on it,ya{ I know}.i will put up closer pics in a bit
mikehusky455
the panel under seat has the gears,forward and rev,are set up with those couplers like a woodspliter shaft,then goes into 2 separate chain-drives inside,then out the right side,opposite tire does kinda kick in when main drive starts slipping,but way to lite in the front end,i have 80lbs of jd suitcase weights I'm adding once I put plow on front.
