Swemill
My D-180 project
Swemill
Unfortunately not allowed to upload more pics here... But you could se my D-180 project if you are interested - with some mods at my site:
http://www.bengan.com/predator/
In the meny to the left - click Wheel Horse. I believe that it's quite unique... =)
Sorry for the only Swedish...
  • Like 4
elcamino/wheelhorse
Sorry I can not read Swedish , but the pictures are worth a 1000 words. Does the Trans Am belong to you ? Thank you so much for sending the pictures.
Regards from here in the USA
Jim Winder
Swemill
Thanks!
Well, It's "only" a Firebird but yes it's mine. =)  Have had it since i was 18, that´s 25 years now.... There has been a lot of projects on that car also through the years. =D
DougC
I took the time and looked at all your pictures and I must say, I am  impressed!   Great job on all your projects............:handgestures-thumbupright:
Pullstart
I like the railing for your home!  That's pretty cool for sure.  Along with the rest of your projects, it's great!
elcamino/wheelhorse
Thanks!
It may only be a FireBird but it is one great looking car. You have put a lot of time and mechanical knowledge in the Firebird.
DennisThornton
"Supporters" upload all they want.
We would love to see your pics!
Holy crap!  I took a few to look at the link!  Wow!
bmsgaffer
:jaw:
I am going to have to get on google translate for that. If you ever have the time, please share all your build stories on this forum! Your builds look incredible!
You can post all the pictures you want by becoming a supporter (its not too expensive) at the top of the page click "Store (Support RS)".
Swemill
Thanks everybody for your nice comments! =)
I will sure consider to be a Supporter next time i have some pics to show.
tommyg
I am really interested in how you pulled this off! This is a weak design with the D series and I had envisioned a coupler like this. Can you share any details? Looks like the hydro pump side is secured by a clamping mechanism of sorts. How about the engine side? Parts machined I assume.
Swemill
Hi tommyg, sorry for the late reply... Yes, the parts are machined! You could see on my site how the coupler looked like as standard. There is also more pics of when it is modified. The pump coupler have i machined some splines in and also cut it in two plus bolts to secure it.
However this coupler didn't work real well.... I put a lot of load on the front hitch and the tractor / frame bends a bit.... which result in forces on the pumpaxle and the axle sealing started to leak oil. The coupler was too tight! Later i remachined / welded it more like the original coupler with a large rubber plate and with more clearance. Now it works well! =)
857 horse
I want you to know......i did read the entire link.....although everyone sends you their best.....
i think the cars are incredible,,,,,,and yes the railing is absolutley off the chain.....All prases to you to your sucess's and well executed projects...
Showed my wife your pics......She wants to know when you will be out of town.....we will just come gets the cars and the house....we will bring 2 big trucks..........thank-you for sharing........
yeah got nice stuff !!!!!!!
  • Similar Content
    • Murph45
      By Murph45
      Fully functional tractor with loader, forks and plow. Could use cosmetic upgrade. I am not using it!
    • BuffaloD200
      By BuffaloD200
      Hey all, I need to install a drive belt on my 75 D180 for my snowblower.  I've looked through a bunch of D-series owner's manuals, and none seem to mention replacement procedure.  The PTO pulley is fixed, save for engaging the PTO and there is minimal movement at the snowthrower pulley. There's no idler or tensioner as far as I can tell.  Do I have to remove the PTO pulley?  That seems to be a required service item.
      Same question for my 80 D200 as well really.
      Using the recommended 4L490W belt.
      Thanks
    • Redtickuleez
      By Redtickuleez
      Hello gentlemen!!! I recently bought a d180 with loader and backhoe. Im looking for serial number.. there is a plate under the steering wheel but its been pajnted over and i can make it out. Can y'all tell me another location and was this tractor pruchased originally with these attachments and any info would be greatly appreciated... Thanks fellow Wheel Horse enthusiasts !!! !! !!!
    • ihatephones
      By ihatephones
      I got a D-180 for $250, and the governor is messed up, the points won't open or close, and I took it apart and was being stupid and messed some stuff up in there, and now I need a new one.
      Where can I get one that's not on eBay for $200?
      I also forgot to say it was a Kohler K482, and I'll throw some pictures of the tractor in as a treat.
    • Southern_Secret
      By Southern_Secret
      Hello fellow Horse Heads long time no post for me, life gets crazy & a lot of things change sometimes but anyhoo. So back a few years ago when I first got my 1994 314-H I had it at my shop going threw it. One of my customers walk past as im working and said, you know I think Iv got a Wheel Horse & im thinking "no you dont buddy". I give him my # to send pics thinking it was a big waste of time & after getting the pics I realized he did have a Wheel Horse! I hand shake bought it right there, asked him to bring it to my store & he said no problem. Well after almost 2 years it is finally in my orbit. I know very little about it other than his father-inlaw got it new and used it around his house moving snow and stuff. His father inlaw moved down south here when his daughter got married and gave the tractor to my customer because he had a farm & his the inlaw had no use for it anymore. Same with every barn find, "it was running when parked" 8 years ago, said one of the axel seal is leaking. Im happy and hope I can get it back in running order soon cause it is going to be handy around the truck farm!!
      I will post Pics as soon as I reinstate my membership
