jonw440 187 #1 Posted November 8, 2015 I am installing my 79360 snowblower on my 93 314-8. How do I adjust the spring tension on the helper lift spring? With the blower on the ground or full up position? Thank you. Share this post Link to post Share on other sites
Racinbob 11,037 #2 Posted November 8, 2015 The manual states to tighten until there is slight tension so that would mean slight tension in the raised position. Share this post Link to post Share on other sites
Ed Kennell 38,021 #3 Posted November 8, 2015 The weight of the blower will stretch the spring to the correct tension when you lower the blower. Share this post Link to post Share on other sites
rodney10954 5 #4 Posted December 7, 2015 i just did mine on my 520 , I had the blower raised all the way to the top then I put the spring on and tightened it down a little, works perfect Share this post Link to post Share on other sites
