Need to identify this single stage snowblower?
By
Rexemouse, in Implements and Attachments
Similar Content
By dave who poos
Hello!
I am looking for any and all snowthrowers that will work on my GT2500. I am trying to find one off FB marketplace but no one ever really posts the model number. Usually just the length. So I look for 42'' throwers but I don't know what will fit. A local seller has this for sale:
He says its 42 but unaware the model, the Wheelhorse logo looks to be from the late 60's/early 70's? It looks like the below thrower:
My question is if that thrower year/model will fit the GT2500. It looks pretty dang simple but I'm not sure. Someone mentioned something about the right size "Quick-hitch" in another post.
By bizzo15
So long story short I scored a two stage snowthrower for my 520xi in the off season and hooked it up to my tractor and finally got a chance to use it this past weekend after we got a storm that dumped about a foot of fresh now. First time out everything was going good and the snowthrower was moving snow like a beast, I did notice though when I got to the berm at the end of the road the blower would shake and vibrate pretty good when going through it. I thought it was just normal operation since the snow tends to be more compacted from the plow, I just made sure to go nice and slow when I got to the end of the driveway and was able to clear my driveway and the neighbors without any issues. Fast forward to the next day and I fired up the tractor to clean up the driveways as we got another couple inches over night. Was able to finish my driveway but halfway through the neighbors when clearing the end of the driveway the blower shook and the suddenly stopped. I shut it down and looked around and noticed the belt was broken, I didn't think too much of it as when I put the blower on the tractor the belt was showing some wear but when I saw how expensive the toro belts are I decided to run it as it looked like it would make it through another season no problem. Once I got it back in the garage I removed the belt and that's when I noticed that something didn't seem right, the spring loaded pulleys on the right side of the pulley box were hanging below the blower frame, I took the chain and belt cover off the blower and noticed there's damage to the main belt pulley on the blower as well. I pulled the pulley box off and noticed that there's groves worn into the metal from the pulley and what looks like some belt rub. Anybody have any clues on what caused the belt to fail? I'm including pictures to hopefully give some clues to those who have used these blowers extensively. I followed the manual while installing the blower but I'm wondering if maybe I don't have something assembled correctly or am missing some crucial part. I'd really hate to spend the money on a new belt only to have it blow because I didn't correct the actual issue. I will say all the bearings seem tight on the blower and there doesn't appear to be any play in the shafts. I look forward to any insight you guys can offer, thanks.
By 608KEB
The tall chute snowthrower on my 520H will twist the kotter pin and disconnect from the lift rod. I've also used kotter keys with worse results. Has this happened to anyone else? I do have 2 washers on the end of the lift rod. Adding maybe 1/8 of a inch to the total length of the lift rod. I've never had a problem with the short chute snowthrower that I have hooked up to my B100.
By Navig8r
I picked up a used single stage that has been sitting. The auger spins, bit things need a little TLC.
What chain lube have you found to work best, and last longest?
Any lube needed on the bearings? Or just replace if stiff?
Thanks!
By wheelhorse-c-161-1979
Youtube video of my 1979 Wheel Horse C-161 throwing some snow!
