oliver2-44
1960 Suburban Hood Stand Repair
oliver2-44
I'm slowly repairing parts of my 1960 suburban 400.  I blasted the hood stand, and need to know which holes are correct and which were added that i should weld up.  Then I'll do some straightening, reblast  and primer.
suburban_hood_stand_front.thumb.JPG.fa85
This is the right side, is the curved cutout and these 4 holes original.
suburban_hoodstand_right_side.thumb.JPG.
this is the left side, are these 2 holes original?
suburban_hood_stand_left_side.thumb.JPG.
Racinbob
Well another trip to the garage and here's my take on it. On the right side only the two holes above and below the little welded block for the exhaust U-bolt should be there. On the left side only the hole near the center for the lift sector. There shouldn't be any holes in the hood brackets other than the ends for the bolts. On the front only the 5/8 hole towards the left should be there. I've got a couple of extra small holes in mine but where there isn't one I think it's safe to assume they shouldn't be there. :)
Racinbob
Oops, I missed your question on the moon shaped cutout. No, it shouldn't be there.:)
  • Similar Content
    • Vaughan32850
      By Vaughan32850
      Has anyone got a WT-30 tiller they can send pictures if pleas? It’s the one fitted with a K91 engine for RJ models.
      Many thanks
    • Jennifer
      By Jennifer
      Husband wants some advice… lol.  So we did an engine swap today on two suburbans because we could not get the one engine to spark all the time to get it running!  The engine ran last year before parking for the winter sleep…. Points were changed out for new the engine was cleaned to make good contact has new spark plug new coil condenser we even switched out the fly wheel today thinking maybe the magnet was weak…. Advice???   It would where are you out yanking on the recoil five or so times and maybe only get the points to fire twice if you’re lucky..  checked the gap and pull again… same thing over and over!  Thanks in advance!
    • Jennifer
      By Jennifer
      Well my husband got new grownup toys!  Lol. Just wanted to post them on here to share!  Sure most seen for sale but they arrived yesterday at our back door glad we found them before it rained again!  Not sure why delivery person made the effort to go to the back of the house…. 🤔🤯
    • Vaughan32850
      By Vaughan32850
      Let’s see all the RJ’s and suburbans that are in Europe / United Kingdom. Here’s my two RJ-58’s.
    • oliver2-44
      By oliver2-44
      So I went to get a haircut this morning in the neighboring town of Kingsland.  Saw a few garage sale sign so I though I'd check them out.   The Garage Sales were a bust, but as I drove through the area, I spotted this 1960 Wheel Horse Suburban being used as a mail box post.    It was chained and locked to the T post and the front rims were sunk well into the dirt like it had been there quite a while.  I momentarily though about knockings on the door,  but the hood was cut, there was no motor and the transmission shifter rubber boot was long gone.  I say it's a 1960 as it had the treadplate foot rest.  It's probable best left for the yard art it's currently being used for.
