Toro 1028 Powershift breaking the drive chain
By
mikekot3, in Implements and Attachments
Similar Content
By Travas
Hello everone reading this. Im currently in the process of building a race mower out of a front engine 8-32 toro. It was sitting outside for the longest time because of a broken axle. It believe it has a vertiical 8 hp b&s that had running. Here is some some photos of it. I put a bifferent transaxle in because it was spare one laying around. I put it on and it fits pretty well. Altho i had to remove all the clutch and shifter parts to get it in, but hey it works. I got a wheel on and tried getting the other off the axle it was on. So i put it in the press and tried for about a half hour before in popped loose. After that it took me about 15 mins and got it off. It was really rusted on there! Put it on the transaxle to how it fits and looks. Now im in the process of drilling a hole the axle for the key in the wheels. Any suggestions or ideas? I will update this project when do some more work on it.
By kurm
You can search for the specs but here are some links:
https://lookup3.toro.com/partdex/index.cfm?xCaller=Toro&lang=us_en
https://lookup3.toro.com/partdex/modlinfo.cfm?xCaller=Toro&o=2&x=22004&b=9900001&e=9999999&m=73552&y=1999&n=523Dxi Garden Tractor&channel=CN
https://lookup3.toro.com/partdex/modlatch.cfm?xCaller=Toro&x=22004
This is a beast! Comes with the 60" deck and also a 48" deck and a new battery. New belt (installed but unused), newer hoses, regular maintenance.
There are wheel weights too but idk if they fit this unit as I've never tried.
758 hours
I got a zero turn and a Kubota tractor and this has sadly become ignored.
By Travas
Okay, no pictures because its at my grandpas farm. no clue what toro it is at all. it appears to be a 1986 11-32. The front is different than a 11-32 and it has no side panels like a 11-32. heres a picture of a 11-32 toro it doesnt have the panels that say toro. the toro logo is on the front and above where panels would be. im just wondering if any body kwows about it because the rear left axle broke off right at the end of the transaxle inside the case. not sure if i can just take the case apart and put a different one in. its not a wheel horse/ toro.
By JoeM
Seen this old Toro on CL the other day. Bad rear end $125. Seems pretty cool.
By Marco
I was getting my riding mower ready for another season, changed the oil, filter, and I tilted the mower on it’s side to change the blades, just as I do year after year (my tractor is about 12 years old!) so once I was done and I got the mower back I found this piece laying on the ground. I have carefully examined the deck and I can’t seem to find where this would go. I tried checking the manual and a couple websites to see if I could identify the piece and no luck, anyone know where this goes? Thank you in advance!
