semper5
Question About attaching snowthrower
semper5
I have a C-Series tractor, 1980 or 1981, black hood.
It came with a snowthrower (snowblower?) already mounted. When I removed it, I didn't take pictures, and wish I did. Now, today, I have attempted to reattach it. I have it attached to the frame via a single bolt that goes all the way through. There is a long bar and tube beneath. The tube has a large nut at one end, and it goes into the hook located at the center rear of the snowthrower. The other end has a long rob, with a piece of flat stock welded to it, and a hole drilled into it. It is just large enough for the pin on the rock shaft (I think thats the term) which normally goes into the mounting point of a mower deck. So I placed the flat stock in such position that it does that. (see pic below).
I routed the belt onto the pulley closest to the engine because in the outer groove it would not line up properly. The auger turns great, needs a bit of oiling I think.
When I put the hydraulic control into up or down, the snowthrower body does nothing. It never rests on the ground, and in the 'up' position the shaft and tube assembly bend to a degree that makes me nervous.
The tube and bar meet up with a pin and there is  nail to keep them together.
It appears that the snowthrower has had some fabricating done to it, not sure if it was out of necessity to keep a worn implement running, or if it was due to modify it to fit my machine. I cannot find much from the data plate (below pic). The measurement is about 36.5 inches at the front.
Does anyone have any suggestions about the tube and bar stock which is supposed to lift? I went 17 pages deep into implements forum, and search was relatively bland for solution.
As always, thanks for your assistance.
Ed Kennell
You need a lift rod and flag.  The flag pin goes in the top hole of the vertical arm on the rock shaft that is about 12" behind the lever in your pic. The rod in your picture is in the deck  lift lever. This only moves the rod up and down. The blower lift rod must be pushed forward to raise the blower.
IMG_3829.thumb.JPG.3a1d7e79e50068029f1eaIMG_1876_(640x480).thumb.jpg.db7fec0850c
Edited by ekennell
gwest_ca
Here is a manual for the 32" model 6-2211 snowthrower
http://www.wheelhorseforum.com/files/file/1676-snowthrower-32in-1968-1969-6-2211-om-ipl-snpdf/
Here is a manual for the 42" snowthrower sold in 1980 for a long frame tractor like yours
http://www.wheelhorseforum.com/files/file/1945-snowthrower-42in-1980-06-42st01-om-tipl-snpdf/
This design was used 1973 until the last in 2007 and very common.
Other than the front attachment to the tractor, the length of the lift tube and snowthrower width they are not all that different.
Garry
semper5
Thank you for the pictures and the file link posted.
As for my lift rod and flag, it appears to be janky. My flag end has no post to fit into the lift arm, but rather a hole. When I try to put a bolt in it and match it up to where it should go, the top of my janky flag hits the bottom of the tractor. Off to find a flag!
Also, I've no wheels on the front of my snowthrower, but I have little steel wedges in the shape of a small skid. Has anyone else seen this?
WNYPCRepair
Yep mine has skids too, it's normal
Ed Kennell
Some blowers had adjustable skids and some had wheels ...one  on each side.    If the wedge shaped skid you refer to is welded across the back of the blower, you still need the side mounted skids or wheels.     You can see part of the right side skid in the lower right corner of the pic.  Also see the front end of the lift tube and attachment to the blower.
Edited by ekennell
  • Similar Content
    • Evguy
      By Evguy
      I’m selling my B100 with 10hp Kohler engine and snowblower. The engine ran when I brought it home 3 years ago and deck ran smoothly. The 8sp gear box will need oil changed.
      I didn’t make headway and need the room for other projects.
      email or message me with questions
    • HyperPete
      By HyperPete
      JD LX-178 with Kawasaki 2 cyl water cooled engine.
      Great shape except for the front hood.  Cracks have been patched, and hinges on the hood itself are broken.  Hood sits fine, just does not open & close properly
      NO DECK!
      Includes (4) John Deere suitcase weights, a John Deere "maintenance kit", and rear chains.
      Well maintained.  Snow blower presently not mounted.
    • Deer hunter
      By Deer hunter
      Does anyone know where I could find a complete engine rebuild kit from for the k-19 ? I absolutely love my c-195 and have had it for years. But the motor let go last fall and I want to rebuild it or upgrade the motor, any suggestions?
    • davidfindlay
      By davidfindlay
      Looking to find a new home for my 84 (I think) C-145. It has a dump trailer with the enclosure for leaves, the PTO impeller to get the leafs into the trailer, the hoses for deck-to-impeller, impeller-to-trailer.
      I haven’t run it in over a year.
      The battery and the cable to the battery probably need to be replaced.
      Comes with a new head gasket still in the bag.
      Seat is cracked but still comfortable.
      Happy to answer questions or take other pictures.
    • dave who poos
      By dave who poos
      Hello!
      I am looking for any and all snowthrowers that will work on my GT2500. I am trying to find one off FB marketplace but no one ever really posts the model number. Usually just the length. So I look for 42'' throwers but I don't know what will fit. A local seller has this for sale:
      He says its 42 but unaware the model, the Wheelhorse logo looks to be from the late 60's/early 70's? It looks like the below thrower:
      My question is if that thrower year/model will fit the GT2500. It looks pretty dang simple but I'm not sure. Someone mentioned something about the right size "Quick-hitch" in another post.
