Pop Pop 1 #1 Posted October 11, 2015 I want to change the bearings on a 42" snow blower 96-42ST01 with the rod that goes all the way through the auger. Do you drive it out after the roll pin removal or is there something else that I need to remove to pull it out of the auger? New at this one. Share this post Link to post Share on other sites
gwest_ca-(File Mod) 11,243 #2 Posted October 11, 2015 Did you get both roll pins out? They drive a second one inside the first one. The shaft should come out with them out of the way.http://www.wheelhorseforum.com/files/file/775-snowthrower-42in-1979-96-42st01-om-tipl-snpdf/Garry Share this post Link to post Share on other sites
Pop Pop 1 #3 Posted October 12, 2015 Thanks gwest-ca I had both pins out just didn't want to pull it out till I knew there wasn't something else I missed. I'm now good to go.Thanks Again Pop Pop Share this post Link to post Share on other sites
can whlvr 993 #4 Posted October 13, 2015 they can be a beasr to get out,ive cut them with a sawz all on both sides of the auger for really seized bars,then I put a new rod in wth new bearings Share this post Link to post Share on other sites
