CRCermak 0 #1 Posted October 11, 2015 On my SK 486 I am restoring should I use tubes in Carlisle tru power tires? They are 23 x 10 1/5 x 12I mainly use tractor for hauling with a dump cart. Also cut paths in fields with it. Share this post Link to post Share on other sites
DennisThornton 4,769 #2 Posted October 11, 2015 Only two reasons I know to put tubes in is if you can't keep air in them or if you want to fill them with heavy but corrosive calcium chloride. Share this post Link to post Share on other sites
Racinbob 11,039 #3 Posted October 11, 2015 I agree with Dennis. I'm quick to throw tubes in them though. Share this post Link to post Share on other sites
pacer 3,168 #4 Posted October 11, 2015 Generally tubes are one of the first things I do. Pulling that old horse out of the weeds or barn with flat tires having cracks in them and hoping they will hold air --- well, not to likely. And, I'm almost certainly gonna paint the rims and pulling the tires eases that job and allows closer inspection of the tires and rims. Share this post Link to post Share on other sites
Shynon 7,459 #5 Posted October 11, 2015 I put tubes in them if I have removed them from the rim, or they won't hold air. If they will sit along time without use, I would tube them because sooner or later when you want to use them they will be flat. 2 Share this post Link to post Share on other sites
JackC 617 #6 Posted October 11, 2015 I put tubes in them if I have removed them from the rim, or they won't hold air. If they will sit along time without use, I would tube them because sooner or later when you want to use them they will be flat. Agree 100%.Now is better than later.That piece of quality built, American history that you are restoring will likely be around for a long time.With tubes in it, the only limitation is you can't drive on the highways. 3 Share this post Link to post Share on other sites
CRCermak 0 #7 Posted October 12, 2015 Thanks on all the replys. Since I purchased all new tires, wheels and the tubes from Miller Tire in Ohio I will have the tubes installed as your all suggesting. I did not know if there was any benefits to not installing them. I will get some pictures on soon of my tractor. Share this post Link to post Share on other sites
