DennisThornton
H60 12v starter? Part number? Anything please...
DennisThornton
Normally I Google for a couple minutes and find what I want.  Sometime longer...  Tonight I've spent half an hour and said heck, lots of guys (some gals?) here know off the top of their heads!  Just ask!  (I even searched here for one...)
Supper time and I'm tired...
My L156, 1966 Lawn Ranger, and what I'd think is the original engine, H60 is missing the starter.  What's the part number of the starter please?  It's missing the carb as well and lo and behold brand new ones are $15 on ebay!  How do you make a whole carb for $15?  I've paid far more for a kit!
But I still can't find a 12 v starter...  All kinds of 120v ones!
slammer302
I have one if your interested its from a tecky i had on a 552
AMC RULES
Brand new 12v Techy starters are currently listed on Ebay.
WNYPCRepair
Screen_Shot_2015-10-10_at_11.03.06_PM.th
That is what the manual shows, but they all go to 120v Edited by WNYPCRepair
DennisThornton
Craig, I checked ebay and found nothing.  What are your search criteria?  Man, i'm usually pretty good at that!
Slammer, my engine is looked up and I've spent no time on it yet because I thought heck, no carb and no starter I'll just look for an engine.  Then I see that ebay has new carbs for $15, well what's a starter and then nothing...
So if I can get a carb cheap and hopefully at least a decent price on a starter I'll see if I can free up a 66 Tecky!
WNYPCRepair
Does this look like it will work?
33607A / 29316 Starter
DennisThornton
I was just there!  And I missed it somehow!  I knew you knew more than just how to fix computers!  I WAS JUST THERE!  Oh well...Thanks my friend!  (How did I miss that....)
And I see that Craig played a role in the engine manual!  I hadn't gotten that far yet..
So thanks to both of my friends!
AMC RULES
:scratchead:  Searched...
"tecumseh starter" on ebay...found this.
E-BAY link deleted
then select H-60 engine in the drop down window. :confusion-shrug: Wasn't too hard.
DennisThornton
Explains why my search for H60 did NOT find the above "H50-70 ".  The description shows:
29965, 32468, -A, 33606, 35765, -A
OS #5752N-EB
But mentions neither the numbers Brian found...
I can find tons of 120 volts
Anyhow, thanks for the ebay link.  Now if could just trade a brand new carb for a starter! <grin>
DennisThornton
Pretty sure from looking at the blower housing that this is what I need:
New-Tecumseh-12V-Starter-35765-32468-33606-35765A-5752Where I am often seeing this, which I thinking is wrong:?u=http%3A%2F%2Fwww.manddsmallengine.com  But I don't know, maybe both with fit?
Retired Wrencher
Dennis I have the # in the garage. I put a new on the 657 that I have give a minute.
AMC RULES
For your battery start ignition, you need the top one pictured there.
DennisThornton
Craig, pics must display differently on different screens.  Mine are left/right.  I'm assuming you are referring to the black round one?  That's what I thought anyway since the opening in the flywheel shroud is round.
Edited by DennisThornton
bell housing - flywheel shroud
AMC RULES
Yep, that's the one Dennis...
the other is 110/120v, plugs into a wall outlet/walk behind blowers.
WNYPCRepair
http://www.amazon.com/Tecumseh-starter-OE-29965-32468-33606/dp/B00OBTT8UO
DennisThornton
Thanks Brian!
And Thank You Craig!  Pictures and all!  Can't get this kind of help ANYWHERE!
Now if I can just find one for the same price as the new carb...
AMC RULES
Yep, looks like price went up $20 since I got mine...   :blink:
the Amazon offer isn't too bad, considering the free shipping.
Retired Wrencher
Thanks Brian!
Dennis the original #was 29965 that is what the Master P/N book says. I hope this helps.
AMC RULES
DennisThornton
Thanks Brian!
Thank you!
  • Similar Content
    • Brad Schroder
      By Brad Schroder
      Looking for 701 (k161) parts. Starter/generator, right side belt cover, left side belt cover, air cleaner housing. Thanks
    • Chuck14025
      By Chuck14025
      1994 520 H.   Starter just clicks.
      1. Battery 12.6V, load test OK.,    New solenoid. Ground good. Key switch tested ok. Wiring diagram shows a 'kill' relay - I can't find it on the tractor. Checked the 3 relays under the battery box - they work. Neutral switch, PTP and seat switch work mechanically.
      2. Not able to find article on this problem when searching. There must be dozens. How do I find them?
      3. Can I test the starter without taking it out?
      4. Is there a 'kill' relay?
      thank you...
    • ToroWheelHorseRookie
      By ToroWheelHorseRookie
      Please Help-- I inherited this work horse from my father in-law after being passed down from his father.  I recently brought my wheel horse in for repairs and the service shop said they were unable to find the part; starter/solenoid.  I did not want to give up on this beast as even the repair shop said this is a well made machine and is better than anything built today. I eventually found the part but because the shop left the part uninstalled I was unable to see how the starter was wired.  Yesterday,  I installed the new starter/solenoid but when I connected the battery terminals the tractor wanted to start on its own.  I quickly disconnected the terminals and analyzed the electrical schematic map but I am baffled on the proper wiring.  I only have a positive (red) battery terminal wire, another red wire, black (ground) wire, and a blue wire with a slot connection.  I included pictures of the starter and the electrical schematic map.  Any help would be much appreciated!! I l would like to fix this on my own as this seems to be a simple wiring issue.  I can add pictures of the tractor itself, but at the moment its under a tarp in a shed at night. Thank you in advance, Matt
      Electrical Guide.pdf
    • RJ Hamner
      By RJ Hamner
      Rebuilding a C160. everything worked prior to rebuild
      Engine was fairly high time so machined .020 over and rebuilt
      Finished rewiring and made sure all the circuits were in order
      Starter would spin the engine. Made new coil wire and installed new spark plug
      Starter won't turn the engine. Tried several times with and without spark plug Same results
      Starter was what I took off the tractor prior to rebuild but can't say it is orininal
      So.......Am I missing something or is a new starter going to be the answer?????
      Thoughts?  Ideas?
      All help/input appreciated
      BTW:  Don't know if it means anything but the gear does not retract when key is moved back to ON
      Bob
    • Postal
      By Postal
      I recently acquired a Kohler K321PT. I want to put it on my Raider 10 but it has a recoil starter. My question is can I put an electric start on this motor and will it bolt up to my Raider 10 to replace the Tecumseh hh100
