Ed Kennell 37,491 #1 Posted October 10, 2015 Just had the required annual state inspection done on my F-150 4X4 . This is what was found on the inside surfaces of all 4 rotors. The outsides , that we all can see were all OK. The inside surfaces were pitted too deep to resurface.I bought the truck new and it has 29,500 miles on it. 4 new rotors and pads = $800. Share this post Link to post Share on other sites
WNYPCRepair 1,875 #2 Posted October 10, 2015 I just had to have mine turned, about the same mileage, and it was covered by warranty Share this post Link to post Share on other sites
Ed Kennell 37,491 #3 Posted October 10, 2015 My warranty timed out at 36 months. 1 Share this post Link to post Share on other sites
stevasaurus 22,527 #4 Posted October 10, 2015 I'll bet it is not just Fords. 5 Share this post Link to post Share on other sites
AMC RULES 37,102 #5 Posted October 10, 2015 Probably them Mopars too. Just sayin'... 3 Share this post Link to post Share on other sites
squonk 40,739 #6 Posted October 10, 2015 They all do it. Even my Tojo will hang up a caliper when you least expect it and then it's rusted rotor city. 1 Share this post Link to post Share on other sites
JAinVA 4,619 #7 Posted October 10, 2015 Probably the liquid calcium cloride that is used for snow removal.The local inspecters here in VA swear my 08 Super duty spent many years up North because of the rust on the dump body.I tell them it only made a half dozen trips between Maine and VA but unfortunately during the winter.The stuff that the DOT's use may be better for the enviroment but the service companies get lots of business from the rash of corroded brake lines.JMHO,JAinVA Share this post Link to post Share on other sites
shallowwatersailor 3,213 #8 Posted October 11, 2015 Ed, its the liquid calcium chloride used on the East Coast. I never had a problem back in Illinois. My 2001 GMC has had four new rotors and calipers (not at the same time) plus all of the brake lines replaced. It only has 49K miles on it. I have almost $2K in brake expense over the five years I've owned it. 1 Share this post Link to post Share on other sites
WNYPCRepair 1,875 #9 Posted October 11, 2015 I used to work at a GM dealership. Brand new cars that have never been driven would have rotors that were rusted so bad they had to be replaced. The mechanics said it was the cheap steel they used 2 Share this post Link to post Share on other sites
squonk 40,739 #10 Posted October 11, 2015 Exactly. The pads clean all the gunk water ect from the rotor surface. When a car sits a long time, or a caliper slider hangs up you get this. One side usually the inside will get rusted out because the caliper isn't freely sliding and the inboard pad isn't touching the rotor surface all the time. It will move under brake pressure but will move too far away from the rotor surface and won't properly clean of the rotor. You will also notice one pad wearing more than the other. And yes, Cheap off shore metal will rot out faster. 1 Share this post Link to post Share on other sites
Wishin4a416 2,190 #11 Posted October 11, 2015 Probably the liquid calcium cloride that is used for snow removal.The local inspecters here in VA swear my 08 Super duty spent many years up North because of the rust on the dump body.I tell them it only made a half dozen trips between Maine and VA but unfortunately during the winter.The stuff that the DOT's use may be better for the enviroment but the service companies get lots of business from the rash of corroded brake lines.JMHO,JAinVA A coworker swears he never had issues until they started using that stuff here about 3 years ago. Could be something to it. Share this post Link to post Share on other sites
squonk 40,739 #12 Posted October 11, 2015 I've seen rotor rot for 20 years. Jeep Grand Cherokees with the rear disc were the worst! 1 Share this post Link to post Share on other sites
mikekot3 92 #13 Posted October 11, 2015 Calcium chloride put on the roads rusts out vehicle fast in new England. The only way to combat is to take it to the car wash after every storm. Some places let you buy a unlimited car wash for 10-20 dollars a month. 1 Share this post Link to post Share on other sites
Ed Kennell 37,491 #14 Posted October 11, 2015 (edited) So, What are the options.1. leave the 4X4 in the garage and use wifes mini van3. daily trips to the car wash4. pressure wash the calipers daily and coat with WD 405. move south6. add a brake that works Edited October 11, 2015 by ekennell 2 Share this post Link to post Share on other sites
mikekot3 92 #15 Posted October 11, 2015 I would take the calipers off once a year and apply sil-glide to the caliper slides otherwise my dad's brake calipers get sticky and the right rear inner rotor surface does not get cleaned from the pads when the brakes are applied. The whole vehicle slide lubrication takes about an hour. Much cheaper than new pads and brake rotors. Share this post Link to post Share on other sites
Ken B 3,134 #16 Posted October 12, 2015 I've seen rotor rot for 20 years. Jeep Grand Cherokees with the rear disc were the worst! You got that right.. I've had my 2003 Grand Cherokee for almost ten yrs. now. I have been thru so many sets of rotors that I've lost count. No rust on the body though. Share this post Link to post Share on other sites
Terry M-(Moderator) 2,158 #17 Posted October 12, 2015 Ed, just curious what year F-150 those were on?? Share this post Link to post Share on other sites
Ed Kennell 37,491 #18 Posted October 12, 2015 (edited) 2010 150 XLT crew 4X4 Edited October 12, 2015 by ekennell Share this post Link to post Share on other sites
Fordiesel69 258 #19 Posted October 12, 2015 14 yrs old........................Its due.$800 for pads and rotors? I would NEVER let a shop do my brakes. That is how you die. If you do them yourself you know its done right & you are saving half the cost. Share this post Link to post Share on other sites
Ed Kennell 37,491 #20 Posted October 12, 2015 Sorry, I fat fingered the year. 2010 5 years old. Share this post Link to post Share on other sites
sorekiwi 761 #21 Posted October 12, 2015 I got 110,000 miles out of the OEM rotors that came on Subaru (primarily driven in Indiana). The cheap chinese rotors that I replaced them with rotted out in about 8000 miles (now in Ohio where they dump a whole lot more salt on the road). 1 Share this post Link to post Share on other sites
305 380 #22 Posted October 12, 2015 (edited) working part time at an auto parts store i see that all the time , usually caused by the caliper hanging up as already stated. those MAY have been able to turn , don't know for sure until you measure them. some rotors don't have much to work with even when they are new , some have enough to turn a couple times. we charge $12 each to turn a rotor or drum.if you had the work done at a repair shop , i have found that most will not have a rotor turned and insist on new onesmy 1995 Chevy S-10 went almost 300,000 miles with the original rotors , my 2003 Chevy 1500 has 156,000 miles with the original rotors still serviceablecheap Chinese parts has also been mentioned ...we have two levels of brake rotors , most people go for the cheapest ones$800 for rotors and pads seams very high Edited October 12, 2015 by 305 2 Share this post Link to post Share on other sites
bmsgaffer 2,043 #23 Posted October 12, 2015 Probably them Mopars too. Just sayin'... On my 2008 Dodge Ram I got over 91,000 miles on original PADS and rotors... Cant complain about this Dodge... I'm in southwestern OH, they use beet juice here for pre-storm prep and a combo beat juice and salt for the roads during the snows.I've seen that problem on vehicles that don't get driven far or as often. Probably the caliper sticking as mentioned or just not cleaning the rust off regularly by driving/stopping hard enough. It would obviously be much worse as you get up into the colder states. 1 Share this post Link to post Share on other sites
Sparky-(Admin) 21,078 #24 Posted October 12, 2015 I always opt for the higher end rotors (and pads) when I buy my brake parts. You get more miles out of them and less headaches!Its best to avoid all the Made in China car parts if possible.Mike........ 2 Share this post Link to post Share on other sites
C-85 669 #25 Posted October 12, 2015 I hate to admit it, but I have had these same issues with my '88 full size Chevy.What gets me the most about this, is the steel brake lines! With all the safety features vehicles have on them, they still use plain steel brakes lines that rust and can blow when you need brakes the most. I would gladly pay the extra to have stainless steel brake lines as standard equipment and it wouldn't cost that much more! I'm surprised that stainless brake lines haven't been required, especially with vehicles lasting much longer these days.C-85 4 Share this post Link to post Share on other sites
