chorusguy 227 #1 Posted October 8, 2015 Never gardened before. I have a bottom or turnover plow. Went out and plowed a couple of rows today. Still too muddy but you know how it is when you have a new toy. Anyway plowed the first row and followed up with a second row and find that there is a gap between the rows about 4 or 5 inches. Is this correct? I put my right wheels in the first ro as I did the second. The plow is pinned in the middle hole so I know I can move it over one slot and that may fix it. Comments? Share this post Link to post Share on other sites
rick 243 #2 Posted October 8, 2015 I think you are on the right track. The Sears (Brinley) plough I bought second hand came with the owner's manual and the mounting position was related to tire track width. Share this post Link to post Share on other sites
Ed Kennell 40,198 #3 Posted October 8, 2015 Can you get a picture of the plow in the furrow and one of the plow and tractor sitting on level flat ground. Both from the rear of course. Share this post Link to post Share on other sites
chorusguy 227 #4 Posted October 8, 2015 Sure but not until SundaySunday. Thanks sent Share this post Link to post Share on other sites
C-101plowerpower 1,606 #5 Posted October 8, 2015 (edited) move the plow over to the right(hitch it in the left hole) set the tractor and plow on level ground. when the plow point is touching the ground the back of the plow should be about an inch off the ground. don't know if you can rotate the plow by loosening two bolts, if you can, put left rear wheel up about 6inches(use a piece of wood or something) loosen the bolts and level the plow. now fasten everything again and you should be good to gothis is how you'd want it to look like(sort of) Edited October 8, 2015 by C-101plowerpower 1 Share this post Link to post Share on other sites
