K241AS 10 HP on a C 105 - Smoking A lot at start
By
SylvanLakeWH, in Engines
Similar Content
By JeremyNzl
Hi Guys,
Looking for some advice,
We rebuilt this k241 with a +.010 piston, Its had a rebore to +.010 but they did it off the manual specs and not the piston.
Not ideal with an aftermarket piston but I wont get caught on this next time.
Its developed this oscillating ting noise, its not the metal cover its there with it on and off,
its 100% from the cam side, does it under low load / slow idle,
Have setoscoped the motor with a screwdriver to the ear, and I cannot locate it.
but its in the top.
Have rechecked valvel clearances x2 already , 1st before initial run, and again day after, very minimal adjustment made after 1st run.
Ting noise clearly heard in the video , appreciate any advice.
Jeremy Nz
https://www.dropbox.com/s/txf8fciaqi5rozg/2021-06-10%2009.08.11.mp4?dl=0
By WheelHorseC101
When I start my engine it will die once i change the throttle from idle to full throttle and when I switch the cold start throttle to what ever down is. It will just die every time
By Bowdoinham Dan
I have a Raider 10 with a K241 engine that won't turn over. It's totally dead. Headlights won't even turn on. I've got a brand new battery and new battery terminal wires, but the small wiring is old and this might be the problem: a disconnection somewhere. So I'm gonna rewire some parts with new wire.
Does anyone know the correct wire gauge to buy? I can't find it listed in the manual.
By BenTheWheelHorseMan
I know I've been mia for a while, so it's good to be back. I was looking at a Massey Ferguson 10 on Craigslist, but it has the Techumseh HH100. I have had much better luck with kohlers and just so happen to have an extra K241 laying around the barn. I was wondering if you guys thought it would be super difficult other than the obvious ( changing wiring and ignition switches) to swap out the motors.
By Bach-Ed
Last year this K241 threw a rod. And as it went it damaged the bore. I later heard that some lower damage can be tolerated when rebuilding. So is this still a usable block or is it only fit to be a boat anchor?
