Bach-Ed
transmission installation
Bach-Ed
I just finished re assembling the tranny I wrote about in "First Gear Slips out".  Hopefully tomorrow I'll close out that thread by reporting the tranny works well.  But here is a different thread.  Maybe I did it the hard way or maybe not but re attaching it to the tractor frame is not a happy experience.  First I slid the frame over the trans and found out I can't lift the tranny with one hand while I insert bolts or even slide the two pilot bolts I made to help align the trans.  Of course the frame rocks side to side while you try to manuover the trans.  So I put the frame on jack stands just ahead that eliminated the rocking but now the frame is higher.  Hum...  then an idea the nylon ratcheting straps I use to hold things on my trailer.  One pulls the trans unevenly so I used a pair under the trans up and over the frame (I tipped the seat pan back out of the way.)  One at the front and one at the rear.  Picking up a little at a time, one then the other I got it in place.  wiggling it I was able to get the bolts in place.
Was this a good way to get the job done?   I ,mean If I had a gantry  and a trans jack and ... but I don't so tell me how to do it better next time.  But it is up and I didn't get hurt or break anything so it wasn't too bad.
953 nut
:twocents-02cents:       I have had good luck using four pieces of all-thread rod and nuts to align and pull up together.
  • Like 5
stevasaurus
You had all the usual issues...the rocking frame, etc.  Jack stands on the frame, got to have those pilot bolts, and I use a floor jack to balance and raise the trans into place.  I like Richard's idea also.  :)
doc724
I used a floor jack also.  I did not have jack stands at the time so one cinder block, two short pieces of 2x8, and one short piece of 3/4 pine were the substitutes.  Necessity is the mother of invention!
squonk
I use a hyd. lift table for the trans, jack stands on the frame to eliminate the rocking and a mower jack on the front wheels. I lift the front of the tractor enough to get the halves lined up, a couple of alignment studs and then 2 bolts to pull it together. a cheap ATV jack also works well for the trans and is more stable than a floor jack.
JC 1965
I used jack stands to hold the frame and a floor jack to lift the trans. Whatever works as long as you get it done.     :thumbs2:
953 nut
Safely!
  • Similar Content
    • giant_g2
      By giant_g2
      Not sure on specific model. This 8 spd came attached to a plow I bought. It had some water in it for a couple weeks according to the prior owner. I drained it, sloshed some diesel in it, drained that, then filled with fresh oil. Spinning the input shaft by hand, I can see the axels turn. Hasn't leaked any oil. I'm not really interested in shipping, so I'd prefer local sales.
    • Doug B
      By Doug B
      Hey guys,I have a dilemma I need some help with. I have a 1969 GT 14 that I replaced the transmission and pump on. For about 2 weeks afterward everything worked great, but while mowing at a pretty good pace I noticed a shudder and the tractor slowed a little but not bad. The more I rode it the slower it got until it barely moves. What stumps me is the hydraulics are still very strong,as in I can back the 3 point under the bumper of my truck and if you lift the arms all the way up the front wheels of the tractor will clear the ground. Have checked the tow valve and checked the internal filter,but no luck. I have also checked and replaced the forward and reverse bypass springs and the lever is moving the cam to full travel, forward and reverse. Any help would be appreciated.
    • mattd860
      By mattd860
      I have developed a kit that allows a Wheel Horse / Toro hydrostatic tractor to be operated by a pedal on the right side of the tractor. The original forward/reverse lever can be retained or removed. The kit includes everything needed to install the pedal kit and installation is simple with the help of a downloadable installation manual. Additionally, only one (1) 1/4" hole will need to be drilled which can be done by a hand drill. No other drilling or cutting will be necessary. Any tractor with this kit can be converted back to stock without any visible evidence that kit was installed. However, you'll never want to do that
      The foot pedal is custom cast in Aluminum, uses brass bushings to minimize wear, and it closely matches the OEM Wheel Horse BRAKE pedal commonly found on 8-speed manual transmission tractors. Modifications were done to the pedal to add the reverse pedal and adapt the pedal to the rest of the kit. For the most part, the pedal looks like it was designed and manufactured by Wheel Horse / Toro. Additionally, a grease fitting has been adapted to the pedal to further minimize wear and tear and if the brass bushings ever wear out they are fully replaceable without having to buy a whole new pedal.
      Here is a link where you can download the installation manual: CLICK HERE
      I am selling these kits for $330 shipped to anywhere in the United States. I offer multi order discounts as well. I will also sell to other countries for additional shipping charges to be determined.
      Thanks!
    • Dylan2342
      By Dylan2342
      New here! hello everyone! In a bit of a pickle here. My father owns a 1993 (I think that is the right year) 520H Wheel Horse. I don't commonly work on tractors but it seemed simple enough. the axle snapped on the left side, so it needed a new transmission. My dad bought a used transmission and I went to work changing everything out. The hydraulic pump that the engine's drive belt attaches to went to a different model/year of tractor, so I had to remove that part and swap it in from the old transmission. In the process I lost all of the oil in the pump (I mention this because I wonder if it has to do with my problem I'm having). When I reassembled everything I started the slow process of filling the transmission. I filled it up and started the engine. When moving the lever forward or backward, it had a tiny bit of power for a little bit and then lost power. The transmission wasn't doing anything, anymore. I though maybe that hydraulic pump needed to be primed, so we took the top hydraulic line off of the hydraulic pump right above the drive belt and used a transfer pump to pump some oil into the pump case. This still didn't work. I don't have enough experience with these hydrostatic transmissions to know if we got a bad transmission or if there is something obvious that I am missing when it comes to a transmission swap. I ask for any insight and help please. If you need pictures or any other info, then let me know what you need. Thank you!
    • Porkskin
      By Porkskin
      I have no understanding of what it is like to push one of these when the trans is disengaged and motion lever is in the forward position as the manual mentions. I hope this is not old ground and that I am not cross posting. With the trans disengaged and motion lever set forward there is still something spinning in and about the transaxle that is giving resistance. I need to know if this is normal or if I should be expecting more of a free wheeling experience. In effect, much less resistance. Thank you for comments or pointing me to a topic that already covers this.
