mr mike 1 #1 Posted September 25, 2015 I need an expert on these things. I think I have found one locally for sale. In rough, non running condition. Trying to avoid over paying. I have the model and serial numbers. Anyone that can help shed some light ? Share this post Link to post Share on other sites
gwest_ca-(File Mod) 11,187 #2 Posted September 25, 2015 Would you mind sharing the model number and serial number?http://www.wheelhorseforum.com/files/file/2384-tractor-1968-500-special-da-om-ipl-snpdf/Garry 1 Share this post Link to post Share on other sites
mr mike 1 #3 Posted September 25, 2015 model 1-7931. Serial 468767 1 Share this post Link to post Share on other sites
gwest_ca-(File Mod) 11,187 #4 Posted September 25, 2015 (edited) It is not often we see consecutive serial numbershttp://www.wheelhorseforum.com/files/file/1827-tractor-1968-charger-9-early-production-da-om-ipl-wiring-snpdf/Garry Edited September 25, 2015 by gwest_ca Share this post Link to post Share on other sites
mr mike 1 #5 Posted September 25, 2015 http://www.wheelhorseforum.com/files/file/1827-tractor-1968-charger-9-early-production-da-om-ipl-wiring-snpdf/Garry is this link specific to the track used tractors? Share this post Link to post Share on other sites
gwest_ca-(File Mod) 11,187 #6 Posted September 25, 2015 http://www.wheelhorseforum.com/files/file/1827-tractor-1968-charger-9-early-production-da-om-ipl-wiring-snpdf/ Garry is this link specific to the track used tractors? No. These are any that have shown up for the 1-7931 model number.Garry Share this post Link to post Share on other sites
Sparky-(Admin) 21,773 #7 Posted September 25, 2015 A complete set of Wheel Horse white walls go for big money....you almost cant overpay.Go get it!!Mike...... Share this post Link to post Share on other sites
953 nut 56,822 #8 Posted September 26, 2015 Are you sure that those are actual white walls and not just painted tires? 1 Share this post Link to post Share on other sites
KC9KAS 4,742 #9 Posted September 26, 2015 My sheet says a 1-7931 is a 1968 Charger 9 Automatic with a 10hp Tecky.Indy 500 is 1-3631 with 4 speed 6hp Tecky. 3 Share this post Link to post Share on other sites
DennisThornton 4,770 #10 Posted September 26, 2015 My sheet says a 1-7931 is a 1968 Charger 9 Automatic with a 10hp Tecky.Indy 500 is 1-3631 with 4 speed 6hp Tecky. Most curious about your "sheet"! Share this post Link to post Share on other sites
Brian01 481 #11 Posted September 26, 2015 Are you sure that those are actual white walls and not just painted tires? i was kind of wondering the same thing, cause whitewalls are usually front and back, right? And in the one pic you can clearly see the backside oof the front tires....no white back there?? I mean I dunno, just my 2¢ Share this post Link to post Share on other sites
DennisThornton 4,770 #12 Posted September 26, 2015 Are you sure that those are actual white walls and not just painted tires? i was kind of wondering the same thing, cause whitewalls are usually front and back, right? And in the one pic you can clearly see the backside oof the front tires....no white back there?? I mean I dunno, just my 2¢ Obviously retouched and off the mark a bit but that in and of itself doesn't mean they weren't whitewalls to start with though I certainly have no idea if they where whitewalls originally or not! But what are original "Wheel Horse" branded tires worth? That they obviously are! Share this post Link to post Share on other sites
squonk 41,968 #13 Posted September 26, 2015 (edited) Wheel Horse supplied tractors to Indy for several years with different models including Suburbans, Front engine round hoods Lawn Rangers, 953/1054. there according to Straight from the Horse's Mouth. I think the 500 Special was a 1 year production tractor commemorating the race Edited September 26, 2015 by squonk 2 Share this post Link to post Share on other sites
Racinbob 11,511 #14 Posted September 26, 2015 They supplied 33 tractors each of those years. The 500 Special was only made in 1968 and had the Tecky H60, not a HH60. Share this post Link to post Share on other sites
MalMac 1,332 #15 Posted September 26, 2015 Back when Radio Equipment out of Indy was supplying the tractors to the speedway, matter of fact they also supplied them to us as a dealer and we were in northwest Indiana. We had a couple of tractors that had Whitewalls that they had sent a message to us wanting them down at the speedway. Seems the tractors got sent to us by mistake. They told us we would have to send them back down at are cost ! Plus it was up to us to replenish them. We offered to just send the wheels a and tire's, they wanted the whole shooting match. Needless to say they never made their way back down to Indy. I do remember the Whitewalls being only on one side, because on one tractor they were mounted wrong way on the front rims. 4 Share this post Link to post Share on other sites
Racinbob 11,511 #17 Posted September 26, 2015 (edited) Would you mind sharing the model number and serial number?http://www.wheelhorseforum.com/files/file/2384-tractor-1968-500-special-da-om-ipl-snpdf/Garry Garry, here's the serial of my 500 Special for the list (1-3631).490313 Edited September 26, 2015 by Racinbob 1 Share this post Link to post Share on other sites
KC9KAS 4,742 #18 Posted September 26, 2015 My sheet says a 1-7931 is a 1968 Charger 9 Automatic with a 10hp Tecky.Indy 500 is 1-3631 with 4 speed 6hp Tecky. Would you mind sharing the model number and serial number?http://www.wheelhorseforum.com/files/file/2384-tractor-1968-500-special-da-om-ipl-snpdf/Garry Garry, here's the serial of my 500 Special for the list (1-3631).490313 There you go! Share this post Link to post Share on other sites
Eric Capozzi 14 #19 Posted September 30, 2018 I just purchased one from a member, m/n 1-7931 s/n 469411 with white wall tires. Someone has painted it and dressed it with the wrong decals. This one will be a work in progress with an almost close restore to the way they were at Indy. 2 2 Share this post Link to post Share on other sites
Eric Capozzi 14 #20 Posted September 30, 2018 On 9/25/2015 at 7:00 PM, gwest_ca said: Would you mind sharing the model number and serial number? http://www.wheelhorseforum.com/files/file/2384-tractor-1968-500-special-da-om-ipl-snpdf/ Garry I purchased one not too long ago. Model No 1-3631 Serial No 490447 for the list 2 Share this post Link to post Share on other sites
AMC RULES 37,144 #21 Posted September 30, 2018 Here's another from the list...# 490614. 1 2 Share this post Link to post Share on other sites
Tankman 3,520 #22 Posted October 4, 2018 (edited) Great Horses! Be sure to update restoration progress, we all suffer from WHA (Wheel Horse Addiction). Edited October 4, 2018 by Tankman 1 Share this post Link to post Share on other sites
TDF5G 2,069 #23 Posted October 17, 2018 On 9/25/2015 at 7:11 PM, 953 nut said: Are you sure that those are actual white walls and not just painted tires? That's what I was wondering. Share this post Link to post Share on other sites
CasualObserver 3,410 #24 Posted October 17, 2018 @TDF5G You know you quoted a 3 year old post there? If you're asking if the white wall tires really existed, yes. Just plug white wall into the search engine. There have been a few topics on them over the years. They're rare, but there are still some out there from the Gasoline Alley pit tractor days. Share this post Link to post Share on other sites
TDF5G 2,069 #25 Posted October 17, 2018 The last post on this thread is Oct 4. I've not checked in on RS for a few weeks now. I'm catching up. No I am not asking if the whitewall tires existed. I am completely aware and familiar with the Indy Specials and the existence of the whitewall tires. The pic that I mentioned appears the tires have been painted on. Share this post Link to post Share on other sites
