djohn24 10 #1 Posted September 22, 2015 Im sure someone has an idea, as to what is going on with this 416H, I recently purchased. I 've searched through the forums and didn't see anything that covered it. I believe it's a 1990. The motion control lever is down in front of the seat. Not on the column When I pull the lever out of neutral and move it forward, it goes all the way forward It doesn't stay where I set it. It just goes wide open. Tried mowing with it and had to constantly hold back on the lever to keep it from running full speed. I'm sure it's something simple but I don't know enough about these yet to figure it out. Any info would be greatly appreciated. Share this post Link to post Share on other sites
rmaynard 15,660 #2 Posted September 22, 2015 Under the seat is your cam plate. There is a nut in the center with a friction washer. You can try tightening that to see if it helps. 1 Share this post Link to post Share on other sites
djohn24 10 #3 Posted September 22, 2015 Thank you Rmaynard....I will give it a try tomorrow. Share this post Link to post Share on other sites
WNYPCRepair 1,923 #4 Posted September 23, 2015 Inspect the washer on top of the cam plate, mine was in two pieces. I assume someone tightened it too tight. 1 Share this post Link to post Share on other sites
rmaynard 15,660 #5 Posted September 23, 2015 Also, the washer and cam plate should be dry, no lubricant. Share this post Link to post Share on other sites
djohn24 10 #6 Posted September 26, 2015 Thank you men! That was it. I tightened the nut a little and it's working well now. Again, Thank you!! 2 Share this post Link to post Share on other sites
