jde853
Just picked up a snow plow and a little confused
jde853
Between my sector channel and the index lever there is a hole in the frame that I'm guessing is supposed to guide a cable that allows the blade to rotate left and right. There is something missing from this  hole that will keep the cable from rubbing and eventually breaking. This is my first time seeing a wheel horse plow and I can't find a photo of this particular one to identify the missing part. I am assuming there should be a cable that controls these parts, not sure because it didn't come with this blade. Hoping someone can give me an idea as to how to get this blade to rotate left and right or maybe refer me to product center.
Model  6411
Serial   552402
Thanks in advance
squonk
I an't tell for sure but it looks like you're missing the rod that goes on the handle down to the triangle part. Is there a lever on the top of the handle?100_7868.thumb.jpg.3b8b7167f85c3fb8610e4
Edited by squonk
Ed Kennell
Typically there is a solid wire (1/8" dia I think) that is fastened to the blade angle locking pin and passes thru the hole in the frame and is connected to the triangular shaped yoke. Another wire connects the yoke to the squeeze handle on the top of the blade angle adjusting lever.  I see you have the yoke, but I can't see if you have the squeeze handle at the top of the lever.
gwest_ca
Believe the 6-411 should be 6-4111 for 1968 or 6-4112 for 1969. In 1969 this was a completing kit sold at the time along with a blade.in a separate package which could have been a 42" or a 54" for the large tractors.
1968 IPL for the 6-4111 Complete blade
http://www.wheelhorseforum.com/files/file/1199-blade-dozer-42in-1968-6-4111-om-ipl-snpdf/
1969 IPL for the 6-4112 Completing kit
http://www.wheelhorseforum.com/files/file/2446-blade-dozer-42in-1969-a-frame-6-4112-completing-package-ipl-snpdf/
1968 and 1969 are the only years where the 552402 serial number fits.
In 1970-1973 there was a model 6-4113 and in 1974 a model 6-4114
Garry
dcrage
Can't tell from your pictures but I believe you are missing the wire rod (like 9 gauge in diameter?) that comes from the lever at the top of the blade handle and goes down to hook on one corner of the triangular piece in front of the handle on the plow frame -- There should be a similar wire rod  running from the triangle to the front to index the blade -- Looks like it is there in your 1st photo, in the 2nd photo the rod I see there looks to be too big for this function -- So I am not sure what I am looking at -- Your concern is about these rods "wearing"?? -- That wire rod will not abrade -- Mine lasted 30+ years -- I replaced it here a couple of years ago but I can't remember what the issue was -- It sure didn't break from rubbing on the frame -- The replacement that I obtained came from Toro
You need to have parts #17 and #19 shown in Gary's reply for  6-4112 Completing kit
Edited by dcrage
squonk
If you need the wire, ceiling grid wire works just fine! :)
  • Like 3
Ed Kennell
Just noticed you have the lower wire rod.  It just needs straightened out and connected to the front hole in the triangle piece. Then make a similar wire to connect the rear hole in the triangle to the squeeze handle at the top of the blade angle lever.     It sounds like you were thinking of using one cable to connect the locking pin to the handle.  That could possible work, but you would have to add a pulley where the triangle is now located so the effective length of the cable would remain constant regardless of the position of the blade angle lever.  That is why the triangle and blade angle lever pivot points are located at the same point.
ronhatch
I used a throttle / choke cable for mine.  Works great!
  • Similar Content
    • Donavon1
      By Donavon1
      Need some help deciding on a brand of engine to buy for my 1054. (Needs to be a diesel 10 hp+) I’m refining used motor oil/cooking oil for fuel for it. So it will have to have an option to run used oil and diesel
    • Joe Reese
      By Joe Reese
      518H Project/Roller Cash - As Is Has last compression/spark last i checked, currently not running. Gauges work when hooked up to battery and engine turns over freely, Has new fuel pump & carb. Comes with original carb & parts
    • Joe Reese
      By Joe Reese
      60 Inch wheel horse mower deck with no rot. All spindles greased and spin smoothly. Comes with mule pulley guard & deck belt covers and the rare offset front mule. Has standard blades installed. Have brand new gator mulching blades for an additional $50 Great       Joe Reese
    • MainelyWheelhorse
      By MainelyWheelhorse
      Hi All, I’m a member of the RedSquare Facebook group, some of you may have seen My tractor there. I have a 1992 312-8 with a 37 inch deck. It came with a house my brother bought, and was given to me. It needed work but just minor things. I mow my lawn with it, and I just bought a plow to push snow/dirt so it’s a working restoration. It was relatively well taken care of by the previous owners so it really just needed a refresh. Anyway see you around the site!
    • cbj75
      By cbj75
      I have a 1975 D200 Wheel Horse with front mount dozer blade, package includes Wheel Horse Dump Trailer, 48" belly mower side discharge, Wheel Horse front and rear wheel weights, turning brakes, rear PTO and 3-point to 2" receiver attachment, and Brinley twin disc harrow. Rear luggage/rack carrier, All refurbished, sandblasted and painted Ford red in 2016. Lots of extra Wheel Horse parts included.
      Package price $3000.00.
      Bryce Johnson
      102 Anglers PT
      Mc Cormick SC 29835
      913-638-6788
      IMG_1962.HEIC IMG_1965.HEIC IMG_0279.HEIC
