Need help Appraising my 1965 wheelhorse Tractor
By
msdhomeplans@gmail.com, in Wheel Horse Tractors
Similar Content
By Donavon1
Need some help deciding on a brand of engine to buy for my 1054. (Needs to be a diesel 10 hp+) I’m refining used motor oil/cooking oil for fuel for it. So it will have to have an option to run used oil and diesel
By Treepep
1975-77 Yanmar YM2000Z. I got as a basket case and did a lot of work on it. Tractor only but I have a new Jbar brush hog that can go with it. 954 hours. It slips out of high gears after a bit or uphill. I Don't know if that is an easy fix. New starter fuel pump to tank. All new belts hoses etc. new front tires and tubes. rear are original.
Its been a couple years since new parts but covered and cared for. Feel free to ask any questions. I could maybe deliver to a reasonable area. Health says its time. I need less responsibility and maint. These machines need to continue to move or they wont.
Thanks guys. Pictures soon. about 40 minutes south from my place.
By Joe Reese
518H Project/Roller Cash - As Is Has last compression/spark last i checked, currently not running. Gauges work when hooked up to battery and engine turns over freely, Has new fuel pump & carb. Comes with original carb & parts
By Joe Reese
60 Inch wheel horse mower deck with no rot. All spindles greased and spin smoothly. Comes with mule pulley guard & deck belt covers and the rare offset front mule. Has standard blades installed. Have brand new gator mulching blades for an additional $50 Great Joe Reese
By MainelyWheelhorse
Hi All, I’m a member of the RedSquare Facebook group, some of you may have seen My tractor there. I have a 1992 312-8 with a 37 inch deck. It came with a house my brother bought, and was given to me. It needed work but just minor things. I mow my lawn with it, and I just bought a plow to push snow/dirt so it’s a working restoration. It was relatively well taken care of by the previous owners so it really just needed a refresh. Anyway see you around the site!
