Need help Appraising my 1965 wheelhorse Tractor
By
msdhomeplans@gmail.com, in Wheel Horse Tractors
Similar Content
By Treepep
1975-77 Yanmar YM2000Z. I got as a basket case and did a lot of work on it. Tractor only but I have a new Jbar brush hog that can go with it. 954 hours. It slips out of high gears after a bit or uphill. I Don't know if that is an easy fix. New starter fuel pump to tank. All new belts hoses etc. new front tires and tubes. rear are original.
Its been a couple years since new parts but covered and cared for. Feel free to ask any questions. I could maybe deliver to a reasonable area. Health says its time. I need less responsibility and maint. These machines need to continue to move or they wont.
Thanks guys. Pictures soon. about 40 minutes south from my place.
By wh315-8
This is a tag on a 1970 Raider 10 from someone on a FB group. Never seen one that had USED on it, it is Model 1-6041 U
Serial 342 USED.
owner thought tag reads 2-6041 U for model but not sure.
I just wonder if this was perhaps a warranty factory return and they used a new id tag this way?
Anyone ever come across something like this?
Typed in the numbers for Clarity.
By Donavon1
Need some help deciding on a brand of engine to buy for my 1054. (Needs to be a diesel 10 hp+) I’m refining used motor oil/cooking oil for fuel for it. So it will have to have an option to run used oil and diesel
By Joe Reese
518H Project/Roller Cash - As Is Has last compression/spark last i checked, currently not running. Gauges work when hooked up to battery and engine turns over freely, Has new fuel pump & carb. Comes with original carb & parts
By Joe Reese
60 Inch wheel horse mower deck with no rot. All spindles greased and spin smoothly. Comes with mule pulley guard & deck belt covers and the rare offset front mule. Has standard blades installed. Have brand new gator mulching blades for an additional $50 Great Joe Reese
