DennisThornton
Wheel Horse Sweepster Started by 1978c81 in Forsale
DennisThornton
Started by 1978c81, Saturday at 11:55 AM
http://www.wheelhorseforum.com/topic/58741-wheel-horse-sweepster/
There's some interest in the add-on grade wheels so I moved this out of the "Forsale" so some of us, and hopefully 1978C81 will join in the chatter and enlighten us!
1978c81
Hello everyone...sorry for the delay..I purchased this with the upgrade. It works well as the factory ones are still there on machine I just flipped them up. This thing is a beast.
DennisThornton
No, no!  You can't get by with just that!  You got to write 2 or 3 lines at least!  :lol:
I understand you bought that way so that hurts the story some, but you are right there to see better.  Did it come with skids, maybe?  And the chains?  Springs?  Does the electric lift work just as you would want it?  Do the brushes hold up well?
1978c81
Not a good author sorry about that.  The electric lift works great....with out weights on the back it will lift the tractors rear wheels in the air. The factory skids are still on there just turned up. They are not that great and dig in to the ground. The brushes are resilient.  Hardly any wear. That being said there is hardly any use on this paticular sweepster.
cheesegrader
With the weight of the bracket, are the springs still able to give some "float" if you hit a high spot.
I just got mine last year.  I'm still tinkering with the adjustments.  Getting the springs just right has been a lot of trial and error.
Your brushes are in MUCH better shape than mine.  I'm still trying to get mine all straightened out.
It is working better now, but the bent brushes caused a bunch of extra vibration and bounce.
Awesome attachment for clearing sticks and twigs in the spring.  Hope it works on leaves this fall, but I'm afraid it might be a little too powerful.
It set a little lower, it dethatches like a tornado!
I may never rake again!
c-series don
I haven't used mine in a while but fall is the best time to de-thatch so I guess I should get those caster wheels on !!!
pfrederi
Here is my homemade approach for my sweepster.
The are very ,very heavy units and even with the weights and chains i have gotten stuck.  i use mine in the spring to sweep the dirt road out of my front yard and back on to the road.  Problem is the slight ditches along the road are usually wet and I have to swwep going up hill as the sweep angle is fixed.
The electric lift works OK but is slow
This is a dedicated set up mounting and demounting the unit is a major PIA.  She only gets an hour or so use per year. I do not like the electric PTO as engagement is harsh...but the KT 17 is an old one from a JD317 and it does not have ball bearings on the crank.
DennisThornton
Thanks guys for more details!  I've got to have one someday!  Probably should get mine for the BCS working first...
  • Similar Content
    • sjoemie himself
      By sjoemie himself
      Hi all.
      This topic will be dedicated to the upgrades and modifications I'm going to do to my 512-D with sweeper attachment.
      The plan was to complete my mini IH 1468 before starting to work on the Wheel Horse but since the leaves are coming down quick I developed an 'itch' to get working on the Wheel Horse.
      First things first, I had to get it running again. New ignition switch and new inline fuse, aswell as cutting out all unnecessary (for now) stuff solved the non-running issue.
      Dashboard wiring seems to be OK
      This is a mess. Two unnecessary relais, one unnecessary switch and a bunch of unnecessary wires everywhere.
      Next up will be a new battery and probably some modifications to the pto-clutch and new oil all around. Also I'm on the lookout for new filter elements for the oilbath filter for the Robin DY41D engine.
      Done for now.
      Major upgrades and or restoration will have to wait until after I finish the Murray to IH 1468 project.
      Running again. Listen to that THUMP!
      Almost forgot to mention.. probably needs some new rubber mounts
      Greetings from the Netherlands, Mark
    • sjoemie himself
      By sjoemie himself
      As requested some pictures of my 1986 Wheel Horse 512-D with sweeper attachment.
    • grinchsr
      By grinchsr
      Is there any parts value in a Wheel Horse sweeper?
