854 barn find project
By
spitfire1, in Restorations, Modifications, & Customizations
Similar Content
By 2003Chevy
Hello All!
Added THREE tractors all at once yesterday(09/16/2025). Two model 854, and one model 855. The two 854 look pretty nice, but are not running right this minute --does not look like much more than a little tinkering/refreshing after sitting for a long time. The 855 was labelled a "parts" tractor, but except for it being Really well-used looking, it seems to be all there so I am not going to consider it out of play yet. The two 854's have rear discharge mower decks...one is a square style deck, the other the rounded style deck.
I think it is really nice that all three are basically the same machine, separated by one year, yet completely different styles--the end of one era and the beginning of another I guess.
There is an ID tag on the 855 (serial number 135166) but on the two 854 tractors, there is No tag under the steering like late models. Are the tags in a different place on older machines? Looking them over, I do not notice anything obvious. The 854 with the lower Kohler engine serial number has the round style mover deck, while the one with the slightly higher engine serial number has the square style deck.
All for now! Be well and stay safe.
[rayg]
By CS-17
Sold!!!
Used 1966 Wheel Horse 856. Includes Kholer K181 8hp engine and 32" deck. Runs and Drives Great!
I received it in non working order, I have since done the following repairs: To Engine/Transmission; New carburetor, fuel pump, fuel line, fuel filter, battery, throttle cable, head bolts, spark plug, regapped points changed oil in engine and transmission and cleaned air filter. To Body; striped and repainted wheels, blades sharpened and primed hood and rear fenders (ready to be painted). This mower is ready to add to a collection or used for every day tasks. Cash on pickup. $800 or best offer. Please feel free to CALL me for details or any question! THANKS for looking! -
By Gcw804
I have a WH 300 series with a Kohler Magnum 10 engine and I cannot for the life of me figure out how to get the choke cable and linkage set so it will work. The numbers on the engine label are worn off the, so I cannot give anyone that information. Does anyone have a picture or can you head me in the right direction.
My arm for the linkage assembly is set at 3 o'clock and 9 o'clock if that helps. There seems to be several different linkage rods for this engine.
Thanks
Gary Williams
By dlashb40
As a retired 61-year-old who inherited 4 of my Grandfather's Wheel Horse tractors, I found a valuable resource in this forum. Here, I connected with Bob Parks (Racinbob), who at the time lived nearby and kindly agreed to help me identify all of them. I ended up keeping the 1964 Model 854 and sold the others. The 854 is a solid, primarily original tractor, and I've been using it since I was 6-years-old. I also had the RM-364 mower deck attachment, which had not been on the tractor for many years. Once again, this forum proved its worth as I could identify and obtain some attachment parts that I was missing. Last week, after some adjustments, I put the mower deck to use and mowed nearly an acre of grass without any issues. The sense of accomplishment in identifying and restoring the equipment was truly inspiring, and I felt like I was a kid again.
As someone who doesn't consider themselves 'mechanically inclined,' I've grown and learned much through this project. I want to express my heartfelt thanks to all of those who guided me and showed me that with the right support, even the most daunting tasks can be tackled.
By cJ_3D
Hey all!
Replacing the drive belt on my 252-h. Anyone know the torque specification for the center screw when I put this pto clutch back on? I know it was on there tight it took a minute for the impact to break it loose. Thanks!
CJ
