Similar Content
By BuffaloD200
'74 D-180
My friction disc in gone on my clutch. I saw the old post about making a new friction disc, so I'm not concerned about that.
I managed to remove the front clutch plate and double v-belt pulley. But I can't separate the two. When I took the assembly off the spiraloc washer popped off on its own. I HAVE READ THE MANUALS.
So I should be able to just remove the pulley from the front clutch and continue with step 4. The v-belt pulley is loose as all hell and flops around like a dead fish. It seems to be hung up on a ring or bearing race.
So my thoughts are grab a BFH or sparky the blue tip wrench.
Is there an unpublished step 3.5, or some trick?
By Poppa Phill
Ive Got an 88 520 and a 60 inch deck.
My 522 gave up the ghost and being up here in maine I refused to buy a JD .
Needing the deck mule with the spring,
also looking for a soft cab.
Thanks
By Joe Reese
60 Inch wheel horse mower deck with no rot. All spindles greased and spin smoothly. Comes with mule pulley guard & deck belt covers and the rare offset front mule. Has standard blades installed. Have brand new gator mulching blades for an additional $50 Great Joe Reese
By giant_g2
By Duramax7man7
Very Solid tractor!
Newer Agro Tires on Rear and Solid Front Turf Tires. Wheel Weights on rear. Fully Swapped Forward Swept axle off of 520h. I ran my 60" Deck on this tractor for over a year with no issues.
Deck it solid top to bottom with no rot and newer blades. Belt and Pulley are good to go!
She's just a little dusty and needs a cleaning. Can get a nice Seat a Tractor Supply.
$1175 OBO -POOS
(248) 9for3-8six3four Text or Call. I do not visit this site enough. God Bless.
NEW SEAT INSTALLED ON THIS TRACTOR! Started it up and ran it for a while yesterday... Forgot how nice this thing is. Tempting to keep it but it's time to send her one her way. GREAT TRACTOR!
