seven 202 #1 Posted September 4, 2015 my electro 12 is leaking were the shift shaft goes into hyd pump.and my question is I don't know what size socket it takes or is it possibly a star socket and there is a arm thing on that shaft how does it come off Share this post Link to post Share on other sites
Trouty56 567 #2 Posted September 4, 2015 I think a roll pin holds the little cam on....then there are 3 bolts or screws...under the plate you removed are 2 o rings....1 around the shaft....and another larger one...you see when you open it up.... A member named Martin.......has a post about it.... @Martin Share this post Link to post Share on other sites
