deere173
Trans drive belt
deere173
Hello. Post from a new member.  I am having a problem with the trans drive belt on a 1990 312 H tractor.  Using the original # 7473 Wheel Horse belt it appears to be too long.  The crude picture I included shows where the belt is contacting itself where it passes beneath the tensioning idler.  This is a fairly new belt and measures about 81 1/2 inches using a tape measure around the outside. Can't find specs on the official belt length but when crossed to other brands they call for a 5/8 X 82 inch belt. It appears I need something less than 81 inches. Has anyone run into this? I see no other way to route the belt.
stevasaurus
Here is the information on the belt lengths you were looking for.
http://www.wheelhorseforum.com/files/file/1850-chart-belts-width-length-listtxt/
It appears that the #7473 is the correct belt for your horse, and by the looks of your drawing, it is too long.  Do you have the old belt?  If not, take some 1/2 clothes line and go around the pulleys, with the tension pulley in the position you think it should be in...mark and measure it.  Use the chart to find the belt number you need.  Hope that helps.  You might want to take a look at the engine mounting bolts and make sure they are not loose or missing...just a thought.  :)
gwest_ca
Looking at this chart
http://www.wheelhorseforum.com/files/file/1997-chart-belts-tractor-drive-1956-1999-15-pages-492-0392pdf/
the 7473 is for the 8-speed models. 5/8" x 81.92"
The 312-H shows a 108501 belt that is 5/8" x 81.5"
Belt dimensions are on the last pages in two lists - numerical and by size.
Garry
Edited by gwest_ca
stevasaurus
Garry, I went into manuals and could not find the belt information for a 1990 312-H, so I used the information for the 1989 312.  Where did you find the belt # information that you have.  Just trying to improve my search skills.  Thanks  :)
Never mind Garry, I found it!!!  Man, I could spend 3 days looking around in the MISC. section in Manuals.  Excellent collection of information you have put together.  Thanks   :handgestures-thumbupright:
Deere173...that 1/2" shorter is probably going to make all the difference.  Belt #108501  :)
Edited by stevasaurus
gwest_ca
I went to the Files and did a search for Chart.
33 of them will come up and I just go through them to find the one I want.
This belt chart in many cases requires a long model number to find the correct one but the later models have the model name listed as well. The whole chart is listed by model year.
Garry
Racinbob
:eusa-think: I'm not sure I'm seeing your drawing correctly and understanding your description of the issue. You've got the idler on the outside of the belt??
Racinbob
Installed it should look like this. :)
stevasaurus
Dang Bob...I think you nailed it.  Man, I must be getting old...and going back and re-reading his post...he has the 81.5 belt.  I am going to go get lost in the Misc. Section now.  :bow-blue:
gwest_ca
Don't all the hydro models use a flat idler?
Garry
Adding
No wonder deere173 is having problems. The online parts list at Toro shows the 312-H as using the 7473 belt along with the 8-speeds.. The 108501 is not even listed.
Edited by gwest_ca
Racinbob
Oops! I'm not familiar with hydros. That could be. Just ignore me :roll:
stevasaurus
Right Garry, but he says his belt is 81.5"...which would be the 108501 length???
gwest_ca
True. Wonder if the belt he has is 5/8" wide or worn?
Garry
DennisThornton
For goodness sake!  You had to go out and find a brand new tractor just to show the idler pulley!  Man!  That's a nice idler pulley!
Racinbob
Yea, great picture but I sure stepped on my...........toes with my reply since we were dealing with a hydro here :wacko:
can whlvr
I have a 90 312-h and went through this because partstree shows the 7473,i put one on from my stash and she  didn't fit,i ended up getting one from tsc but cant remember the length off hand
  • Similar Content
    • jmack
      By jmack
      What’s the correct v-belt size for a xi drive belt connecting to a 60” deck?
      Just shredded mine today.
    • ryobi.warrior
      By ryobi.warrior
      The belt on my Wheel Horse 314-8 mower deck (05-37SC01) appears to be contacting the deck bracket between the spindle pulleys. I am a novice when it comes to Wheel Horse maintenance (at best), but this does not seem correct.
      I recently inherited this Wheel Horse, so I do not know the maintenance history. Unfortunately, the mechanic who previously worked on it was a no-show for a scheduled maintenance visit.
      Any advice on how to address this? Thanks in advance... this seems like a great forum and I'm looking forward to spending time here!
      Photos (please forgive the dirt and grime, I plan to clean it up!): https://imgur.com/a/4PknZuJ
    • seven
      By seven
      Does anyone know what size belt is required for the rear mounted tiller off of a charger 12
    • JackHorse
      By JackHorse
      Hi Guys, Had a random occurrence this week. Mowing along with my C85 eight speed in 1 low (grass was thick and wet), went to depress clutch and the drive belt jumped off the idler. I've had this tractor 3 years and it's been working great.  The belt itself looks good except the top of it was a bit chewed up in a short section which I believe happened after it came off.  I put the belt back on and continued to mow with no further issue.  Any ideas as to why this would happen or adjustments I might need to make to prevent another incident? Thanks
    • Jrblanke
      By Jrblanke
      Good morning everyone!
      I had my 312H out for the first time this past weekend and the more I drove it, the harder it was to get out of reverse. I added about a quart of oil before I started (was just barely on the dip stick before) and as I mowed, it got harder and harder to come out of reverse. If I barely put it in reverse (where I was moving slow) I could shift it out. But if I pulled the joy stick all the way back where I was moving quickly, I would have to either hit the brake, or slam it in forward in order to get it out of reverse.  I am beginning to think it was linkage related, like maybe something is getting stuck when I put it all the way in reverse. Anyone had a similar issue? What is the fix?
