Countdown To Christmas!
mower deck attachment 42 rear discharge C120
By
cafoose, in Implements and Attachments
Similar Content
By Charles99
ok I'm new to these and first time really working on small engines. i have a k301 engine. i ordered the tune up kit with new coil, condenser, and points. after installed it won't fire. it turns over that's it. I made sure everything is grounded and the points have proper gap . 20. i have voltage at the coil i have spark at the points. i took the plug out that has spark. I'm not sure what else to do I'm about to start putting old parts back on and see if that changes anything. it did run before hand pretty well actually besides an occasion sputter or hiccup.
By PAguy
Hello gents!
I find myself with a question for the forum before I go down the path of ripping my deck apart in the middle of the season.
I have a 42 inch rear discharge 78350 that seems to have developed a crack at the center spindle (photo attached). At first I thought I had unbalanced blade issue bc the deck will vibrate something fearce. Long story short took it off got everything sharp and freshly greased. Started it up and it had the vibration again that reverberates through the deck. Now it's not as as bad as before but at the wrong angle or first starting it just vibrates loudly. So looked around and found the crack at the center spindle.
Debating if a simple weld would be sufficient for this crack or it would need more extensive repair? I don't weld myself but before I bothered the guy that farms the property thought I would ask here for thoughts if someone has had this issue since I was not seeing something in the forum.
Appreciate your guys help and thoughts.
By MSBiker
Well it looks like I'm out of luck. I have been looking for blades for my Lawn Ranger and having zero luck. I have tried Wheel Horse part numbers 7908, 7909. Toro part numbers 8777, and 53322 and no one has anything like this. I was thinking about doing a cut down, but finding right hand and left hand blades seems to be the problem.
Anyone making blades, constructing blades, got a work around, etc? My blades are usable, but that is about it.
By Brockport Bill
48" Mower Deck - Side Discharge model # 78361 -- # 312000163. This mower is listed as being manufactured at the near end of Wheel Horse production for this deck in 2012. This mower is in very good condition used only one season on small yard. Well cared for and stored indoors. The deck has double right side pulley for optional bagger attachment. Any owner who cares for this mower will have a great investment of a classic WH deck to last decades. Cash pick up Poughkeepsie, NY area. No returns. Please send p.m if interested
By jmack
What’s the correct v-belt size for a xi drive belt connecting to a 60” deck?
Just shredded mine today.
