KC9KAS
875 Problems
KC9KAS
Last week I tightened the 2 screws that hold pressure on the plastic piece that holds the trans in a constant speed. I also had the belt guard off.
I thought that I had the belt riding below the guide instead of on top of the guide once the guard was re-installed, as the belt was rubbing & smoking.
The tractor would barely pull itself on level ground and I was about 1/2 mile from home.
My wife pulled me home with the B-80. I had the engine running wide open and motion control full forward. The pull strap actually had some slack in it most of the time, so I don't think pulling the 875 caused a problem...I could be wrong...
I bought a new belt, installed it and it still barely pulls it-self. Everything seems to be tight and working like it should.
Any help in trouble-shooting this issue is greatly appreciated!
953 nut
The "Tow Valve" is closed isn't it?
KC9KAS
I have mowed with this tractor for 2 years and have not found the tow valve, so my guess it is closed.
I see where the tow valve should be but there is a plug in the spot and not a "TEE" or "slot" to turn anything.
wfrpalm
The valve is on the trans opposite of the pulley and facing the rear, it is a nut that is be loosened with a 1/2" wrench               ( about a 1/4 turn) to tow the tractor or make it free wheel. It should be only snugged when tightening. If it is loose now that is the problem.
stevasaurus
KC, check page 5 in this manual.  It is actually a 1/2" head bolt that is pointed at the end to open and close the valve.  I know you have an 875, but it is the same as my 876.  Took me a while to find mine also.  The manual explains the valve.  :)  It is on the pump between the pump and the trans on the left side of the horse.
http://www.wheelhorseforum.com/files/file/562-tractor-1966-876-da-om-ipl-wiring-snpdf/
squonk
If Ken has mowed for 2 yrs. and hasn't found this valve yet I think it's unlikely that the valve is now open.I'm thinking a hub key or the trans has given up. Do you feel any resistance in the hydro lever? When my hydro went the pressure build up forced the hydro lever back to neutral. It turned out my hydro motor was bad. The pump built up the pressure but the motor would not let it flow causing it to have too much pressure.
Here is another thought,The motion control arm where it connects to the trans has an allen screw locking it to the shaft on the hydro. Maybe when you tightened the plastic cam, it is now too tight and that arm is now slipping on that shaft. If it slips you can move that lever forward but the shaft on the trans doesn't move. That could be why you tightened the plastic cam? Before my hydro went that allen screw fell out of my C-160 and I had erratic speed control. Someone got in there before I got it trying to correct a problem and made things worse by playing with that screw.
Edited by squonk
KC9KAS
I think the seat has to be raised and you get to this through a hole in the front of the "tool" box. Mine is actually an ALLEN head, and it is tight enough that I couldn't easily move it, so I didn't.
Hubs are tight. The motion control arm that moves the shaft appears to be tight....I can see the shaft rotate side to side when the motion control lever is moved.
It was very low on fluid, although it didn't have any major leaks. I check it regularly, but it now was really low. Still have problems after refilling with ATF.
  • Similar Content
    • Dylan2342
      By Dylan2342
      New here! hello everyone! In a bit of a pickle here. My father owns a 1993 (I think that is the right year) 520H Wheel Horse. I don't commonly work on tractors but it seemed simple enough. the axle snapped on the left side, so it needed a new transmission. My dad bought a used transmission and I went to work changing everything out. The hydraulic pump that the engine's drive belt attaches to went to a different model/year of tractor, so I had to remove that part and swap it in from the old transmission. In the process I lost all of the oil in the pump (I mention this because I wonder if it has to do with my problem I'm having). When I reassembled everything I started the slow process of filling the transmission. I filled it up and started the engine. When moving the lever forward or backward, it had a tiny bit of power for a little bit and then lost power. The transmission wasn't doing anything, anymore. I though maybe that hydraulic pump needed to be primed, so we took the top hydraulic line off of the hydraulic pump right above the drive belt and used a transfer pump to pump some oil into the pump case. This still didn't work. I don't have enough experience with these hydrostatic transmissions to know if we got a bad transmission or if there is something obvious that I am missing when it comes to a transmission swap. I ask for any insight and help please. If you need pictures or any other info, then let me know what you need. Thank you!
