Badco.
Fisrt time wheel horse owner!
MikesRJ
:text-welcomeconfetti: to :rs:
:wwp:
JC 1965
Hello and :WRS:
Aldon
Welcome to the forum.
Here is what you should be seeing. Go to your post at the bottom you should see options
image.thumb.jpg.46a63e09decc0cdf51b2791eclick on edit and at bottom after entering any text you should see click the text and you should be able to choose photos. THey will load into a queue. You then have to hit the PLUS sign in upper left of queued photo.image.thumb.jpg.8f7cadf2cdc1f34307a2a23aif this is not the case your challenge may be due to limitations on not being a "Forum Supporter". Being a Forum Supporter opens or frees up photo options quite a bit.
wrightorchid
Welcome to the club.  Please become a supporter.  Seems like PA has a wealth of horses....
If you plan to restore over winter, you might need two horses, so you can plow when necessary....:):)
Edited by wrightorchid
Badco.
Thanks for your help Aldon!
Ed Kennell
:WRS:          Better start making room....these  RED HORSES  really multiply fast.
        :rs:
AMC RULES
:text-yeahthat:  Bringing home your first :wh: means...   :handgestures-thumbupright:
you're definitely going to need more storage space.
                     :WRS:
muz123
Welcome to the forum!
KC9KAS
Thor27
Welcome, I look forward to following your build as I plan on redoing my C105 too.
tunahead72
Welcome, fellow Pennsylvanian, and have fun with your new tractor!
So, do you know Terry (TT)?
SylvanLakeWH
Older thread but welcome from a fellow c105 owner!
