HorseHead1089 100 #1 Posted August 24, 2015 I picked up a 310-8 red/silver no black hood stripe, but there is no dial a height on it. i was hoping to use this for a plow/grader tractor, and i figure this would have been helpful, is it worth adding if i can find the parts? or will it work fine? this a future project tractor and would like some info on the tractor before i startup the thread. 1 Share this post Link to post Share on other sites
slammer302 2,156 #2 Posted August 24, 2015 I would add it parts should be easy to find Sent from my XT1080 using Tapatalk Share this post Link to post Share on other sites
Racinbob 12,423 #3 Posted August 24, 2015 I have to agree. You'll want it for pushing snow. Post in the wanted section and you'll probably find one. It's a very simple install. Share this post Link to post Share on other sites
elcamino/wheelhorse 9,362 #4 Posted August 24, 2015 Before I found the Forum I ordered mine from Toro , very easy install , just had to cut the plate near the brake set to get it to fit. Share this post Link to post Share on other sites
HorseHead1089 100 #5 Posted August 25, 2015 oh ok thanks! plenty of parts tractors around, hopfully a build thread will commence soon Share this post Link to post Share on other sites
Butch 194 #6 Posted August 25, 2015 I ordered my kit from Toro a couple years ago. It was only around $60. It included newplates that were cut. New decals. Plus all the hardware for the dial a height. So checkwith Toro. Share this post Link to post Share on other sites
MikesRJ 558 #7 Posted August 25, 2015 (edited) Or sleezebay ... Edited August 25, 2015 by MikesRJ Share this post Link to post Share on other sites
Tankman 3,523 #8 Posted August 25, 2015 Found a complete set up for the dial a height. Easy enough to add to the Work Horse I "found" (psssssss don't mention the Work Horse to the Ms.).Needed the height adjust to move snow off my hundred yard stone drive.Either up or down doesn't get it right. Share this post Link to post Share on other sites
HorseHead1089 100 #9 Posted August 25, 2015 To order a kit, how did you order it, off a store or through phone or email, to get a rough start on where to look. Share this post Link to post Share on other sites
Tankman 3,523 #10 Posted August 26, 2015 To order a kit, how did you order it, off a store or through phone or email, to get a rough start on where to look. I would look here, place an ad in the wanted section. I picked my set off eBay, $10. Set was complete. Share this post Link to post Share on other sites
Butch 194 #11 Posted August 26, 2015 Toro part number #86725. It will include two black dash plates already cut out. It will also include5 new decals which them alone can be expensive. Plus it will have all of the dial height hardware.Ib paid around $60 for it several years ago and never used it! Sold it on Ebay! You may have to gothrough Toro. 1 Share this post Link to post Share on other sites
Alrashid2 429 #12 Posted November 26, 2024 Bummer, something must have changed since 2015 and 2024. Can't find the kit anywhere online... Share this post Link to post Share on other sites
Racinbob 12,423 #13 Posted November 26, 2024 You should be able to piece a 'kit' together. I Lift Manual 1985 8-6725 Dial-A-Hite TIPL.pdf - All years - RedSquare Wheel Horse Forum Share this post Link to post Share on other sites
Alrashid2 429 #14 Posted November 26, 2024 Thanks for sharing this! Going to try Share this post Link to post Share on other sites
