austin gill
transaxle axle seal 8 speed
austin gill
Ive seen alot of talk on axle seals and them being very cheep at $6.00 but i have a wheel horse B-80 that just started leaking gear oil badly and was wondering if anyone could kindly help me on whare to get a seal?? thank you
..Austin
gwest_ca
Napa is one place that supplies SKF or Chicago Rawhide (CR) seals. Once you find the original seal number there are lists pined at the top of this transmission section that will change the part numbers over. Axle diameters are 1" and 1-1/8" so make sure you get the correct one. Post again if you need more help.
Garry
stevasaurus
You either have 1" or 1 1/8" axles...
1" axles use SKF 9815.....TORO # 100863
1 1/8" axles use SKF 11050....TORO # 100443
Like Garry said...NAPA or Motion Industries or your TORO dealer.  :)  There is usually a reason they start leaking, make sure your bearing is OK by checking for up and down or side to side play.  You should have very little to no play.
  • Like 5
Racinbob
Search the number on Ebay. I just bought 6 SKF 9815's for $15.00 shipped.
