Pete Monteiro 32 #1 Posted August 21, 2015 I built up a 25 command and I cant find a smaller rear end pulley that will fit properly. The pulleys I found will fit but there offset and belt wont line up properly. I need more wheel speed for the class I'm in. I have a 5 inch on the motor. Want to go for a 4 or 5 inch on the rear. Does anyone know where I can get one ? Share this post Link to post Share on other sites
daveoman1966 3,788 #2 Posted August 21, 2015 What is the diameter of the INPUT SHAFT on your trans? What is the WIDTH of pulley you need? I presume it uses a 5/8" belt....right? Share this post Link to post Share on other sites
Pete Monteiro 32 #3 Posted August 21, 2015 (edited) The shaft bore is 5/8 it is the 8 speed rear end. Yes 5/8" belt. Also the factory rear pulley has a 1/8 inch keyway and all the pulleys on line have 3/16 key for the 5/8 bore at least thats all I can find online. Are you pulling guys making your own pulleys for the rear? Very frustrating lol It is a 400 series Horse Edited August 21, 2015 by Pete Monteiro Share this post Link to post Share on other sites
Spareparts 85 #4 Posted August 21, 2015 Do you know anyone that has a mill, trim the 3/16" key down to make it a step key, I have seen keys before but for the life can't remember where. Share this post Link to post Share on other sites
Pete Monteiro 32 #5 Posted August 22, 2015 Didnt even think of that. Thanks. Now I need to find a pulley that will allighn correctly. Share this post Link to post Share on other sites
stevasaurus 23,035 #6 Posted August 22, 2015 Send a PM to racinfool40. He has a ton of pulleys from the Wheel Horse transmissions, he might just have what you are looking for. Share this post Link to post Share on other sites
wallfish 17,383 #7 Posted August 22, 2015 You could always go bigger on the engine pulley too.Not sure why they won't line up, the engine pulley can slide in and out on the shaft.Can you post some pics of your setup? Share this post Link to post Share on other sites
Pete Monteiro 32 #8 Posted August 23, 2015 5 inches on the engine is about the biggest pulley I can go without modifying the belt guard. I will post some pics tomorrow. Share this post Link to post Share on other sites
