daveoman1966 3,812 #1 Posted August 17, 2015 I am trying to identify this CAST IRON Pulley and need help. It is pulley # 5878 and is for the old Double-D Shaft configuration. I have two of these and they are NEW OLD STOCK...found in a box of other new pulleys. This 5878 pulley is shaped exactly like the dome-shape 5877 (110846) pulley but it is bigger diameter. The dia of the 5878 pulley is 3.75" and the smaller pulley 5877 is only 3.25" in diameter. Every on-line source I look at says "Discontinued", but they never show what it was originally used on....what mower deck, that is.Can any body HELP....HELP HELPMy direct email is:daveoman@windstream.net Share this post Link to post Share on other sites
chorusguy 227 #2 Posted August 17, 2015 Part appears in 1965 42" side discharge parts list Share this post Link to post Share on other sites
daveoman1966 3,812 #3 Posted August 17, 2015 would that be deck # RM-425. If so, Toro doesn't show a schematic. The next in line... RM-426 is shown, but the side pulleys on it are # 5877. Can you post a schematic of RM-425 .... Share this post Link to post Share on other sites
gwest_ca-(File Mod) 11,251 #4 Posted August 17, 2015 (edited) http://www.wheelhorseforum.com/files/file/599-mower-rotary-42in-sd-1965-rm-425-om-ipl-snpdf/The file is upside down at the moment. Got it fixed.Garry Edited August 18, 2015 by gwest_ca Share this post Link to post Share on other sites
daveoman1966 3,812 #5 Posted August 18, 2015 EXCELLENT.... I don't git no better 'n this. THANX LOADS. Actually, you've outdone all expectations... I had antoher pulley... a DOUBLE BELT Pulley with DOUBLE-D configuration that I couldn't ID either. It is # 5876 and is a 2-belt pulley for the center spindle. It is 3 1/2" dia on BOTH top and bottom pulleys. As it turns out, it TOO is for the RM-425 deck. I found it in the .pdf download schematic, along with the 5878 pulley. Here is a pic of it... Thanx for pre-empting my search to ID it too.RM-325 is curious... LT pulley is 5878 (3.75 dia) Center is 5876 (3.5 dia) and RT side is 5877 (3.25 dia). Why...? This has me REALLY BAFFLED.... Share this post Link to post Share on other sites
