BOB ELLISON
C160 AXLE COMING OUT
chorusguy
Any updates on this project?
BOB ELLISON
I have been working on it as much as I can ,I got both c160 apart and now I'm in the process of cleaning and painting
as you can see by the before and after pictures I'm going as fast as I can, now what I need is a diagram of how to reassemble
the 5088 transaxle
. does the bolts face left or right on the differential. all the diagrams I have do not show the bolts. And
 what is the torque specifications for the differential..it not going to be a show  piece but it will look like a nice wheel horse.
chorusguy
Wow.  Great.
stevasaurus
You rebuild the trans in the shallow side of the case.  The nuts on the differential have to face the deeper side of case...brake drum side...or left side.  Use new nylon nuts and just tighten them all the same...probably around 12 to 15 foot pounds.  :)  Did you down load that manual that was in a post on page 1 of your thread??
Fabricate something like this to hold your trans case when you start to put it back together.
http://www.wheelhorseforum.com/topic/53181-trans-rebuild-stand/
Edited by stevasaurus
BOB ELLISON
Yes I did get all the manuals I could for my tractor .all the pictures in the repair manual just show a diagram but none
show which way the bolts go .I read that if you don't put the differential in the right way it could damage the trans.
the bolts will hit the gears I have watched a lot on you tube about transaxles and not one is for the 4.010
some one said it was a 5088 transaxle .
   thank you steveasaurus
WHX??
Jeepers cats Bob....looks like you went from a errant c clip to a full blown restore...if  your not  careful you is gonna have one fine WH!!!:text-coolphotos:
BOB ELLISON
I plan on it WHX5 been doing a lot of work to the old girl. I got the frame fixed and painted, this is the frame from the 1977 and it
was broken in half . the guy bolted a 1/2" plate to the bottom 2 bolts on the axle plate , it was about 8"   long and almost touched
the ground for a plow . well he hit something and broke the 2 bottom bolts off in axle. (some people are so dumb) I fixed it and
decided to use it for my build. I've  got the axle back together and now  I'm cleaning everything and painting as I go. this is what I've
got so far ,a lot of work but will be a nice horse.  by the way who is good with kohler k341 engines , I have a problem with mine
NEED ADVICE ON KOHLER K341. In the last 2 pictures the governor pin is bent don't know how he did but I would like to replace
it what is involved to get old one out ?? and I found this c clip lying under lifters  someone said it is from c clip holds the valve rotator together
manuals are not that good about explaining how to fix it.
by the way the engine on the old frame will go on painted frame later after I fix it
Warning:Unsupervised
Hey' I'll be darned, you found the C-clip that held your axle in.:teasing-tease:
Sorry' I don't know where that clip goes, but man you sure did get involved in the ol' Horse, no doubt about that & doin such a great job and all, I'll just bring one of mine over and you can do it too. Well' after saying it' I best wait till yours is together I'd hate for mine to end up as a doner..lol  Look'n real good there Bob, real good!:text-coolphotos:
Edited by 123GO
Sorry so late on the draw on this but here's some excellent gasket maker Toyota uses called FIPG that will be great for a Wheel Horse case sealant.  Part numbers -- Toyota Seal Packing 103 (FIPG) 00295-00103  --.
I do my timing belt & water pump on my Tundra every 100k and the first time I went to get parts I learned Toy rarely uses gaskets. Believe it or not Toy uses no oil pan or water pump gaskets at all on most engines, you just put a thin layer of FIPG on both sides and mate things together and let me tell you this stuff is excellent. It sets up very fast and not once have I ever had a leak with it on anything. My Tundra now has 348k miles and not a leak one anywhere so they certainly know something others don't. :confusion-scratchheadblue:???
 Not the cheapest sealant, not by any means but it works fast & real easy to use and the best thing is it works the very first time. There are other companies making their own version of FIPG that's cheaper, myself I just never cared because this one works so good. I certainly never want to tear my Tundra water pump down twice over saving a few bucks on a sealant. :angry-steamingears:
Sorry late on the draw, been busy unpacking, still moving in here.
Edited by 123GO
  • Similar Content
    • D_Mac
      By D_Mac
      Going to possibly pick up a bolens 1256 that's been sitting outside for sometime. My question to any of you who have had one or knows about them is how to get them to free wheel. I would need to push it from a field to a driveway. From what I have read there is a pin on the right hand side, on the hub of the rear wheel that you pull out to get the wheel to free spin. Is there any other tow or dump valve on these machines? Also any thoughts on this model in general. Never had one before. Also never have had a wisconsin engine either. What should I expect?
    • BuffaloD200
      By BuffaloD200
      '74 D-180
      My friction disc in gone on my clutch.  I saw the old post about making a new friction disc, so I'm not concerned about that.
      I managed to remove the front clutch plate and double v-belt pulley.  But I can't separate the two.  When I took the assembly off the spiraloc washer popped off on its own.  I HAVE READ THE MANUALS.
      So I should be able to just remove the pulley from the front clutch and continue with step 4.  The v-belt pulley is loose as all hell and flops around like a dead fish.  It seems to be hung up on a ring or bearing race.
      So my thoughts are grab a BFH or sparky the blue tip wrench.
      Is there an unpublished step 3.5, or some trick?
    • robertsonchris06@gmail.co
      By robertsonchris06@gmail.co
      After using my 8-25 mower successfully for several years I noticed the belts were very worn. I replaced the belts and used the mower several mowings this past summer with no problems until as I was mowing the last time the mower would not move in any gear. After stopping and inspecting the traction belt it was almost completely destroyed. Prior to this I had noticed that the engage/disengage lever was getting hard to activate (very stiff). Has anyone had a similar thing happen?
      Thanks in advance for any help on this problem.
      Just want to keep my mower running.
      Chris
    • MachXXII
      By MachXXII
      I’m trying to restore my grandfathers old 252-H to use around my property. The tires are shot and the rims aren’t too far behind. Anyone have any recommendations for rims and tires that would fit well on it?
      right now it has 22 x 7.50 - 12 on the back and 15 x 6 - 6 on the front.
    • 87buickt
      By 87buickt
      Newb here, recently purchased a b310 that now runs with snow thrower, plow, and mower deck for what I believe to be a good deal for $200. My question to all y’all gurus is what am I missing for my snow thrower attachment? I’d like to get it squared away before winter I know I’m going to need a belt and chain any help would be greatly appreciated.
