ziggyswheelhorse
417-a
ziggyswheelhorse
Any body know what the part number is for a hydro filter is and what oil should I use?
Sent from my XT1080 using Tapatalk
shallowwatersailor
It uses 10W-30 motor oil. I use Mobil 1 10W-30 synthetic in my tractors. I would use a NAPA 1410 filter in place of the Toro filter. It has flats on the end that makes it easier to remove.
ziggyswheelhorse
OK thanks is there a seal kit to reseal the deck lift valve and the hydro?
gwest_ca
I believe the part numbers in this manual have changed but the last time I checked Toro still had them.
http://www.wheelhorseforum.com/files/file/45-lift-hydraulic-valve-and-cylinder-sm-810242r3pdf/
Check them here. If priced should be available from any Toro dealer.
http://www.partstree.com/parts/
A well established hydraulics shop should also have them.
Garry
