Similar Content
By D_Mac
Going to possibly pick up a bolens 1256 that's been sitting outside for sometime. My question to any of you who have had one or knows about them is how to get them to free wheel. I would need to push it from a field to a driveway. From what I have read there is a pin on the right hand side, on the hub of the rear wheel that you pull out to get the wheel to free spin. Is there any other tow or dump valve on these machines? Also any thoughts on this model in general. Never had one before. Also never have had a wisconsin engine either. What should I expect?
By BuffaloD200
'74 D-180
My friction disc in gone on my clutch. I saw the old post about making a new friction disc, so I'm not concerned about that.
I managed to remove the front clutch plate and double v-belt pulley. But I can't separate the two. When I took the assembly off the spiraloc washer popped off on its own. I HAVE READ THE MANUALS.
So I should be able to just remove the pulley from the front clutch and continue with step 4. The v-belt pulley is loose as all hell and flops around like a dead fish. It seems to be hung up on a ring or bearing race.
So my thoughts are grab a BFH or sparky the blue tip wrench.
Is there an unpublished step 3.5, or some trick?
By rustyedge1
39" Dozer Blade for early Lawn Ranger. All welds look good and the nuts on cutting edge are free and turn. Grease zerk is also free and working.
PM for details. Cash only. No shipping. Pick up only at my location.
Solid blade. PM for details. 200.00 OBO cash only.
By robertsonchris06@gmail.co
After using my 8-25 mower successfully for several years I noticed the belts were very worn. I replaced the belts and used the mower several mowings this past summer with no problems until as I was mowing the last time the mower would not move in any gear. After stopping and inspecting the traction belt it was almost completely destroyed. Prior to this I had noticed that the engage/disengage lever was getting hard to activate (very stiff). Has anyone had a similar thing happen?
Thanks in advance for any help on this problem.
Just want to keep my mower running.
Chris
By MachXXII
I’m trying to restore my grandfathers old 252-H to use around my property. The tires are shot and the rims aren’t too far behind. Anyone have any recommendations for rims and tires that would fit well on it?
right now it has 22 x 7.50 - 12 on the back and 15 x 6 - 6 on the front.
