Similar Content
By DennisThornton
One of the most detailed I've seen.
https://www.homemadetools.net/forum/garden-tractor-loader-videos-85395?utm_source=newsletter&utm_medium=email&utm_campaign=05-21-21&utm_content=05-21-21-181510&fi=181510#post181510
By BMW1
On my D200, when I turn the steering wheel all the way to the left, it has a tight turn radius, but when I turn it all the way to the right, the turn radius is significantly wider.
The tie rods appear to be adjusted evenly.
Anyone have a similar problem and what was done to fix it? The steering does have quite a bit of play, at least 1/4 to 1/2 turn of the wheel.
By Off Track Horse
Okay, so I just know just enough about engines to do basic care & know when something is wrong. I have what presented as a hydraulic leak on my 416H with fluid spraying everywhere from under the center of the tractor and it is really only significant when the PTO is engaged. I took the mowing deck off today expecting to find a cracked hose or loose fitting. Wrong! Instead I found fluid coming out from the steering shaft on the opposite side of what I am finding is called the "steering fitting lube" piece on the Toro parts website. So where it shows part #7 going in the fluid is leaking out of the other side. I'm really at a loss on this one.
By wheel horse guy
Help I just recently porched a D250 to add to my collection and wish to install power steering Hydraulic. I under stand I might be able to find help on this WH forum. Thank you The wheel hoarse guy
By Bear G
I was thinking about putting this brush guard on my ‘69 GT-14. So much for thinking.. I don’t really care for it..
Original thought was it would look cool & help protect that exposed fuel tank.
. Pretty sure I’m going to abort on this project.
Back to the drawing board..
Yes, I know, wrong hood decals for ‘69..
This hood is off a ‘70 I had.
