jackhammer 546 #26 Posted August 9, 2015 Tuna, reading your story on saving the horse I must hand it to you. Good job and to Rexemouse for following through.A video of that would have been great, Good luck guys with that projectRick Share this post Link to post Share on other sites
Kelsey 91 #27 Posted August 9, 2015 For some unknown reason, I keep coming back to these WHphotos and look in utter amazement. Share this post Link to post Share on other sites
Wheel-N-It 2,969 #28 Posted August 10, 2015 All I can say to that project is I remember when I bought my 312-8 brand new, and I wanted a loader but could not afford it. Seeing yours brought back alot of memories of my days spent daydreaming about a loader, and wishing I had the funds to purchase one. Share this post Link to post Share on other sites
WNYPCRepair 1,921 #29 Posted August 10, 2015 All I can say to that project is I remember when I bought my 312-8 brand new, and I wanted a loader but could not afford it. Seeing yours brought back alot of memories of my days spent daydreaming about a loader, and wishing I had the funds to purchase one. I just moved dirt today with a shovel and wagon. I still dream of having a loader. 3 Share this post Link to post Share on other sites
Forest Road 594 #30 Posted August 11, 2015 Wow!!! Job well done!!! Sent from my iPhone using Tapatalk Share this post Link to post Share on other sites
WHX?? 49,106 #31 Posted August 11, 2015 Absolutely freakin AWESOME.... my list of chores for that girl would have no end! 1 Share this post Link to post Share on other sites
HorseHead1089 100 #32 Posted August 11, 2015 when you swapped the hubs and tires, did you do the spindles as well ? kind looks like the tractor i propped up a little bit. Share this post Link to post Share on other sites
Rexemouse 88 #33 Posted August 16, 2015 Thanks everyone for the feedback, Iv'e been working the snot out of it this past week clearing land behind my house. It does an awesome job of pealing large pricker bushes right out of the ground. I will get some dirty pictures posted once I get the ag's and weights on it.I believe the tractor sits slightly higher in the front due to the 520 front axle swap. It sat perfectly level with the regular 416 front axle. I created a post awhile ago for the hub swap http://www.wheelhorseforum.com/topic/57457-how-to-trailer-hub-conversionupgrade-for-520h/. 2 Share this post Link to post Share on other sites
bmsgaffer 2,045 #34 Posted August 16, 2015 I believe the tractor sits slightly higher in the front due to the 520 front axle swap. It sat perfectly level with the regular 416 front axle. I created a post awhile ago for the hub swap http://www.wheelhorseforum.com/topic/57457-how-to-trailer-hub-conversionupgrade-for-520h/. What size rear tires do you have on it?Some 300 series came with smaller front/rear tires (15" front/22" rear). If you have 22's that would be why you are riding low out back (as your 520 conversion with hubs would have put the larger 16's out front). You can throw some 23's on it should even it out.If not, just ignore me! Share this post Link to post Share on other sites
HorseFixer 2,012 #35 Posted August 17, 2015 Very nice Job!Duke Approved! Share this post Link to post Share on other sites
GT14 243 #36 Posted August 19, 2015 Man you do nice work! I want a loader real bad, I am moving 5T of stone by hand right now. 1 Share this post Link to post Share on other sites
dennist 139 #37 Posted August 21, 2015 Justin, Excellent job, it looks terrific. Share this post Link to post Share on other sites
Rexemouse 88 #38 Posted August 22, 2015 I've been using the loader to clear a large area behind my property. The area is full of nasty bushes, huge vines, fallen trees, and large mounds of stubborn dirt. I have worked this little loader so hard and it doesn't seem to care. I don't think I can break it if I tried. Here is a video of Tunaslayet and I moving a huge rock that we pulled out of the mini jungle. I'm not sure what it weighs, but it is seriously heavy.https://www.youtube.com/watch?v=utwPdprSvyEHere we are moving a large mound of stubborn dirt. We probably moved 10-15 yards of dirt in just a few hours (2 evenings after work). https://www.youtube.com/watch?v=eq1whwMtxjEThanks everyone for the support. Thanks Dennis for the 416-8. It plows like a champ. 2 Share this post Link to post Share on other sites
Rexemouse 88 #39 Posted June 6, 2016 (edited) It’s been almost a year since I built my 312-8 loader and I wanted to share my experience. This tractor has been invaluable to me and I find new uses for it almost on a weekly basis. Upgrading the rear wheels to 26x12 Ag’s is by far the best modification i made. They provide insane traction, increased travel speed, and make the loader way less tippy. They also look great. This mod requires raising the seat pan 1” and using wider rims with the correct offset. 520rims are ideal but can be hard to find. The rims on my tractor are fabricated from two wheels (notice weld seam). Filling the tires makes a huge difference! The momentum of the fluid is very noticeable when plowing or plunging into loose dirt. The 26x12 wheels can hold almost 100lb of washer fluid each. I am currently not using wheel weights and I have yet to get stuck. I was previously running 23x8.5 AGs (unfilled w/ 50lb weights) and had serious traction issues, even with light bucket loads. Turf tires are useless. The 520 1” spindles and gear reduction steering are absolutely essential. This setup is so solid and certainly not a weak point. The amount of weight in the bucket is most noticeable in the steering. Even with the gear reduction system, the tractor needs to be moving to steer. It is important to know the limitations of the machine. I actually blew my differential by testing the traction. I bought these good year 26x12 super-terras used from a guy in CT. They were knife-sharpened to increase traction for pulling. The differential broke in 1st-low while peeling up un-disturbed earth with my bucket. This machine can easily load full buckets of loose-dirt and stone, but really shouldn’t be used for any real ground engagement IMO. What I love most about these tractors is that I was able to replace the transmission in less than 4 hours. I have used the snot out of this machine. It is awesome for what it is and will suit my needs for years to come. Thanks, -Justin These old wheelhorse carts are huge and take a heavy load! Was gonna sell it, but i am finding too many uses for it. ^Loader as is sits today. AG's up front simply for the looks. Its definitely pretty worked and dirty. ^These were all pulled out of the woods behind my house. Couldn't have done this without the loader. ^ I moved this rock no problem. Its a giant. ^ I moved this rock too. ^ standard hitch added. All the parts are from harbor freight. ^ I bough this hitch because it had the lower mount I need for towing my cart. ^Knife-sharpened endges. Notice weld seam in rim. ^ Tractor with 23x8.5 AGs. Edited June 6, 2016 by Rexemouse 10 Share this post Link to post Share on other sites
WNYPCRepair 1,921 #40 Posted June 6, 2016 Very nice. Share this post Link to post Share on other sites
JAinVA 4,620 #41 Posted June 6, 2016 (edited) Justin, You are the man.Love what you have done with the machine.I have bought the PF engineering plans for the loader you have based on what you posted.Does the 312 you own have 1" axles or 1 1/8".If they are the 1 inch then blowing the differential will continue,I'm afraid.Based on your posts I am building a 312a to handle the loader duties.Gear reduction steering and a 400 series trans.The engnine choice is open at this time but a 20 horse Onan is appealing.Love the helmeted kitty.Luck,JimAnderson Edited June 6, 2016 by JAinVA Share this post Link to post Share on other sites
Rexemouse 88 #42 Posted June 6, 2016 Jim, That is a good point about the trasmission. The 312 is from the 90s and did have the 1-1/8 axle 8-pinion diff. I replaced it with an identical transmission from a 416-8. Regarding your engine choice, I find the single 12 to be sufficient for everything I do. A 14 or 16 single would be my first choice for a loader. The singles are extremely reliable, fuel efficient, and much quieter than the twins. They also like to sit and idle, which i find myself doing a lot. I just love the quiet and unremitting heartbeat of a single kohler while manually loading the bucket or tying up some roots/ vines to pull out. Although a 20HP Onan chugging through 2 feet of snow is a sound I cant get enough of. Thanks for the feedback, -Justin 4 Share this post Link to post Share on other sites
JAinVA 4,620 #43 Posted June 6, 2016 (edited) Justin, I am still trying to figure out which later WHs have the 8 pinion transaxles .I sold a late 80's 310 transaxle to a member here that had the 1"axles.I have a couple of 14 horse Kohlers in the shop now waiting for rebuild and will put one on the Dark Horse for now.The 20 horse Onan is in pieces but I really like the smoothness of the thing.The 416h has me spoiled.Everybody is busy but keep us updated. A lot of oldsters like what you are in to.Luck,JimAnderson Edited June 6, 2016 by JAinVA 2 Share this post Link to post Share on other sites
roadapples 6,983 #44 Posted June 6, 2016 Once you have a loader you`ll never want to be without it. The older I get, the less appealing a shovel and a wheelbarrow are... 5 Share this post Link to post Share on other sites
JAinVA 4,620 #45 Posted June 6, 2016 I have access to two loaders here.A 440 JD track loader with a 1 yrd bucket and a Ford 3400 with 1/2 yrd bucket.They both do the job but I am thinking something more able to work up closer to things that don't like getting hit like the house or pole barn.I have many hours with a shovel moving dirt and am just about through with that as mid sixties approach.Good job Rexemouse.JimAnderson 2 Share this post Link to post Share on other sites
WHX?? 49,106 #46 Posted June 6, 2016 Boggles the mind to think it was once in a dumpster 2 Share this post Link to post Share on other sites
WNYPCRepair 1,921 #47 Posted June 6, 2016 On August 9, 2015 at 9:15 PM, WNYPCRepair said: I just moved dirt today with a shovel and wagon. I still dream of having a loader. So, I built a loader. No more shovel. Amazing the things you can use it for. 1 Share this post Link to post Share on other sites
TunaSlayet 88 #48 Posted June 13, 2016 (edited) Will someone please start convincing Rexymouse to order the plans from PF engineering for the backhoe. I am working on him, but I think a little peer pressure from the red square might help. Just a matter of time really. I know Wallfish has a PF backhoe. Perhaps he could provide a first hand opinion on the backhoe design and usefulness?? Edited June 13, 2016 by TunaSlayet 1 Share this post Link to post Share on other sites
C-101plowerpower 1,605 #49 Posted June 13, 2016 47 minutes ago, TunaSlayet said: Will someone please start convincing Rexymouse to order the plans from PF engineering for the backhoe. I am working on him, but I think a little peer pressure from the red square might help. Just a matter of time really. I know Wallfish has a PF backhoe. Perhaps he could provide a first hand opinion on the backhoe design and usefulness?? http://myoldmachine.com/files/file/18-pdf-backhoe-plans/ Share this post Link to post Share on other sites
r1jakecfd 51 #50 Posted July 14, 2016 Beautiful job on the restoration and loader! I have a 310-8 with a PF loader and loved it until the transmission mounting plate cracked. I think I'm going to duplicate your subframe as it supports the rear-end and keeps everything in line, reducing torsional stress on the frame. What are you using for a cutting edge on the bucket? I had a friend that had a bunch of used Zamboni cutting edges that he got from a rink. I cut it to length and it is all set up for recessed bolts. It is reversible as well as being super sharp so BE CAREFUL! It is the best modification I've ever done on the loader. It cuts through sod like a knife! Highly recommend. It's hardened steel too vs. just welding on a mild steel edge. The other issue I had with the 310 that I'm not sure you have with the 312 is the transaxle is a 4 pinion vs. an 8 pinion on the 520's and other models. I actually broke my pinions using the loader and had to split the trans case. Not fun but a good experience looking inside. Congrats again on the project. I wish I had more time to play in the garage! John Essex, MA 1 Share this post Link to post Share on other sites
