JaredO 0 #1 Posted August 3, 2015 Hi Guys. My Charger 10 has been leaking from the trans since I got it. Its not a lot but enough to leave a stain on the floor after I use it. So I finally got some time to tear it apart and find where it's coming from. I took the trans off the tractor and saw that it was coming out of where the control goes in to the hydro unit. I took the control block off and behind I found two orings which I originally thought was the problem. But it turns out that right behind the orings is a seal where the control shaft goes in to the hydro unit and that is what is leaking. Now my problem is that I cannot find this seal anywhere. I can't even find a part # for it. I tried my local Toro dealer but they were no help and I can usually jump on this site and find what I need using the search function, but not this time. Also will I be able to replace the seal without disassembling the hydro unit? Share this post Link to post Share on other sites
gwest_ca-(File Mod) 11,115 #2 Posted August 3, 2015 Would this be it?http://www.wheelhorseforum.com/search/?q=103461The 103461 has been replaced by 25-3210 at Toro.The CR (Chicago Rawhide/SKF) replacement is 6763.688" shaft1.191" OD.188" deepGarry Share this post Link to post Share on other sites
