JaredO
Charger 10 Leaking
JaredO
Hi Guys.  My Charger 10 has been leaking from the trans since I got it.  Its not a lot but enough to leave a stain on the floor after I use it.  So I finally got some time to tear it apart and find where it's coming from.  I took the trans off the tractor and saw that it was coming out of where the control goes in to the hydro unit.  I took the control block off and behind I found two orings which I originally thought was the problem.  But it turns out that right behind the orings is a seal where the control shaft goes in to the hydro unit and that is what is leaking.  Now my problem is that I cannot find this seal anywhere.  I can't even find a part # for it.  I tried my local Toro dealer but they were no help and I can usually jump on this site and find what I need using the search function, but not this time.  Also will I be able to replace the seal without disassembling the hydro unit?
gwest_ca
Would this be it?
http://www.wheelhorseforum.com/search/?q=103461
The 103461 has been replaced by 25-3210 at Toro.
The CR (Chicago Rawhide/SKF) replacement is 6763
.688" shaft
1.191" OD
.188" deep
Garry
