DanD
Hello Red Square Community!
My father recently rebuilt a 1990 520-H he found at a junk yard and surprised me with it as a birthday present. I've done a lot of searching for guidance on implements/attachments that will fit this particular model but am coming up short. I would love to get a rototiller, snow thrower, and a blade but I have no idea what will work. My model number is 41-20OE01. Will any wheel horse attachment prior to 1990 work with this tractor? I'm new to this so any help would be much appreciated. Thank you for your time!
cdsl810
Most of the 300/400/500 and C series attachments will work with the 520-H.
The tricky part is that in order for attachments that came from the C, 300/400 tractors often require an extra adapter, extension, or unique lever to allow them to fit the 520-H--even though they are identical in all other aspects. It's because the frame of the 500 series is longer than the others. A prime example is the snow blade: The C, 300/400/500 blades are all basically the same... the 520-H requires a frame extension to allow it to attach at the back Attach-a-Matic hitch--AND it has a different angle adjustment lever that has a "zig-zag" bend in it instead of being just straight.
roadapples
Is the frame actually longer or is it because of the swept forward axle? Just curious.
KC9KAS
:WRS:
MalMac
I believe it's because of the forward swept axel add a few inches to accommodate the 60" deck.
cheesegrader
I used a 48" blade on a 520 for two years without the extension bracket.
The back of the blade rubbed the front of the right tire when the blade was angled.
Not bad, but annoying, and it wore the paint off the blade.
The extension gives about 4" extra clearance needed for the forward swept front axle.
Problem is, they are hard to find, and go for about $150 with the extension bracket, lift point brace and offset lever arm.
  • Similar Content
    • 2drxploder
      By 2drxploder
      looking for a tiller for my 520h as well as some wheel weights. also maybe some good chrome hubcaps
      located in charlotte nc area
    • Redtickuleez
      By Redtickuleez
      Hello gentlemen!!! I recently bought a d180 with loader and backhoe. Im looking for serial number.. there is a plate under the steering wheel but its been pajnted over and i can make it out. Can y'all tell me another location and was this tractor pruchased originally with these attachments and any info would be greatly appreciated... Thanks fellow Wheel Horse enthusiasts !!! !! !!!
    • Aaron Coffman
      By Aaron Coffman
      Hi Red Square Community,
      I am looking into purchasing the below pictured "POND" Walk Away. The unit itself has the cast in “POND” on the chain reduction housing. The two main things I am looking to learn are what value is typical for these to sell for. This one has a Briggs & Stratton model “N” engine. It runs and drives, but the throttle linkage needs some adjusting. It comes with a cultivator and plow implement.
      Secondly, I was wondering if there is any way to determine what year specifically this Pond is from. The seller believes late 1940s and not 1950s. I am new to these machines, so I am looking for some guidance. Thank you in advance!
    • Joe Reese
      By Joe Reese
      Wheelhorse Snow blower Fits c100's 500's etc. with a front mule setup. Works. Comes with lift Flag & Lift spring relief. Also have a set of rear tire chains for additional - $50
      Have a set of custom exctra heavy rear wheel weights if interested as well. $75
      Snow Blower Only, Tractor Not For Sale.
    • 87 416-8 horse
      By 87 416-8 horse
      I’m looking for wheel horse tractors for sale or for parts in the Eastern Nebraska or western Iowa area. Preferably 8 speed manuals. Pm me or comment with what you have. The worst I could say is it’s out of my price or distance range. Edit: engine is not important, it’s going to get an engine swap.
      Thanks,
      John
