Jay1775
211a going in wrong direction
Jay1775
I have a 211a i just bought for $15. I got it running. However when i shift in reverse it goes slow forward, and when i shift forward it goes in reverse fast. I am not sure if someone messed with the linkages or what. Any help would be appreciated.
below are pictures of the shift linkage as i have it shifted into forward gear. Does anyone of pics of the linkage or able to tell me why its moving in opposite directions from what i am shifting it into?
Edited by Jay1775
Jay1775
https://youtu.be/1BmwvMLdQ4g
Here is a clip of me testing the wheel horse yesterday. Notice when i shift the gear lever which way the wh goes. In reverse it flies to the point when breaking the front wheels come up off the ground and in forward in moves slowly making me think that the gears have been reversed some how. Edited by Jay1775
Don1977
The drive belt has been installed the wrong way. The belt twist on the engine pulley. Take it off and twist it the other way.
Jay1775
Don thanks. Do you have a diagram or a pic of the correct way to install it?
Don1977
Go to Partstree  then Toro and look under Lawn & Garden Tractors. Then look for 211A. Then transmission drive belt..
Jay1775
Ok i just went out and checked the belt. It was twisted because the v pulley and idler pulley had been switched sometime ago. However after getting the pulleys and belt correct it is still moving forward in reverse and forward when placed in revers. Is it me or does it look like some flipped the cam speed lever upside down? Is that possible to do?
The the images and let me know what you guys think.
Edited by Jay1775
Don1977
The parts picture shows the top side of the cam. Your picture is look at the bottom side. I still think you have the belt twisted wrong.
bmsgaffer
Check when you have it running the fan should be blowing air over the pump, should be pretty easy to tell that way.
Jay1775
Jay1775
Does anyone else have a 211a that they can take pics and send of the cam plate and routing of the belt? This may help me solve the issue one and for all.
thanks
stevasaurus
Jay, I put a message in the Shout box for some help with your horse...maybe someone with a 211a will see it.  :)
Edited by stevasaurus
bmsgaffer
Jay:
The cam plate in your video is working correctly as it would on the bigger horses. The short throw is reverse and the long throw is forward.
As per your question in your video, if the belt is twisted the wrong way then the hydro pump will spin backwards and everything will work backwards (The big twist- which side of the belt goes above or below the other-, not the little twist in the belt from one pulley to the next). I think that is what you have going on here.
If you set your camera up to record the hydro fan while you are cranking, you may be able to tell which way its turning. I dug around for a while and found a really good image on how your belt is supposed to go. This view is from the top of the tractor (a cut away) so it looks from your video as if your front idlers are backwards (vee and flat). Hard to tell exactly from the video.
385r1036.thumb.gif.3b279d93c2dde9476145b
Edited by bmsgaffer
Clarification.
stevasaurus
That looks like an excellent picture Brandon...let's see what happens and thanks for hanging in there.  :)
Molon_Labe
Jay, from what I see in the video, it looks like the flat and v-pulleys have been interchanged. Yours looks to have the flat pulley on the bottom and the V pulley above it, opposite the diagram.
squonk
I don't know who designed that belt drive arrangement, but after seeing that pic, they need to be committed! :eusa-think:
  • Like 4
Jay1775
Thank you guys for all stepping in to assist me. I hope the videos i provide help. I try to post pics and videos as quick as possible to keep this going and solve the issue quickly.
i also swapped the pulleys in hopes ti match the diagram.
Edited by Jay1775
Jay1775
Bingo!!!! I swapped the pulleys and reran the belt. Now she is working like she should. You guys are awesome. Thank you guys foreverything and i hope the videos and diagrams can help someone else down the road.
  • Like 5
Molon_Labe
That deserves a big thumbs up for hanging in there! Glad you got 'er going!
  • Like 4
bmsgaffer
Glad to hear it Jay! We love keepin them horses running smoothly :handgestures-thumbupright:  :wh:
Jay1775
I am just fortunate that you guys were patient and also hung in there with me. You guys rock. Since i have you guys gere i should ask...
By chance does anyone know of what attachment blades or snow throwers might match up with 211a? I am bot sure of any model numbers or how they would hook up. Also do i need a special bracket ?
Edited by Jay1775
bmsgaffer
I would guess whatever fits the 200 series from your era will cross over, but im not sure. There are some guys on here that have some 200 series tractors that can jump in hopefully.
As I'm sure you have noticed, we love to help all horses but the smaller vertical shaft tractors are not as common to find on here. They had more specific attachments that were only made for a few years. Now if you happen to pickup a horizontal shaft, classic style C series, 300, 400, or 500 series you will find LOTs of help and tons of attachments and spare parts as they generally interchange from the 1970's through late 2000's.
If you post a wanted ad for the things you are looking for in the classifieds you may have some people that can help out.
Jay1775
Thanks for info. Does the same go for c100 and c200? Do they have a lot of parts?
bmsgaffer
C-100 is a part of the C series, so yes almost anything will cross over across the whole attachmatic system. They are considered "garden tractors" versus the 200 series "lawn tractors". They are just a bit bigger and are rated for ground engaging equipment like tillers, plows, grader blades, etc.
C-200 wasnt a production model (there is a custom built one floating around though), D-200 was but those will have special D series attachments only.
Attachmatic Tractor Rundown (not gospel, but it gets you an idea):
  • Early C series are C-xx0 where xx is horsepower (8,10,12,14,16) square looking long red hoods
  • Later C series are C-xx5 where xx is horsepower (8,10,12,14,16,17) they are also known as 'blackhoods' as they had a plack painted insert in the hood. There was also a C-195 but it was a much larger tractor known as "the super-C"
  • 3xx,4xx,5xx - (08,10,12,14,16,18,20) Not all series have all HP and the higher series had a heavier duty transmission (in general, not always strictly followed) with the 520 being the special one which had heavier duty front axles and steering on the later models. (Does NOT apply to any with "xi" after the number)
If you spend a day browsing this site and reading topics and looking through the gallery you will get a pretty good handle on all these tractors have to offer. Edited by bmsgaffer
Jay1775
Thank you Bmsgaffer. All the info you have provided has been very helpful. I appreciate your help and thos that assisted me with fixing my 211a. I am sure to have more questions however, i am going to read over the site and get a better understanding of the Wheel Horses.
who knows i may become a WH
addict lol
  • Similar Content
    • cheesegrader
      By cheesegrader
      About a decade ago, I bought a conversion kit here to remove the column drive lever and convert to a foot pedal for a 520h.
      I would like to convert a second tractor, and I need to replace one of the linkage bars on the first one that has cracked, but I can't find the vendor any more.
      Does anyone remember who made this awesome mod, and where I can find them?
    • giant_g2
      By giant_g2
    • Doug B
      By Doug B
      Hey guys,I have a dilemma I need some help with. I have a 1969 GT 14 that I replaced the transmission and pump on. For about 2 weeks afterward everything worked great, but while mowing at a pretty good pace I noticed a shudder and the tractor slowed a little but not bad. The more I rode it the slower it got until it barely moves. What stumps me is the hydraulics are still very strong,as in I can back the 3 point under the bumper of my truck and if you lift the arms all the way up the front wheels of the tractor will clear the ground. Have checked the tow valve and checked the internal filter,but no luck. I have also checked and replaced the forward and reverse bypass springs and the lever is moving the cam to full travel, forward and reverse. Any help would be appreciated.
    • mattd860
      By mattd860
      I have developed a kit that allows a Wheel Horse / Toro hydrostatic tractor to be operated by a pedal on the right side of the tractor. The original forward/reverse lever can be retained or removed. The kit includes everything needed to install the pedal kit and installation is simple with the help of a downloadable installation manual. Additionally, only one (1) 1/4" hole will need to be drilled which can be done by a hand drill. No other drilling or cutting will be necessary. Any tractor with this kit can be converted back to stock without any visible evidence that kit was installed. However, you'll never want to do that
      The kit operates very simply and similar to modern tractors. When the pedal is pushed forwards the tractor will move forwards. When the reverse pedal is pressed downwards, the tractor will moved in reverse. If the operator takes his foot of the pedal at any time, the pedal will automatically center itself and the hydrostatic transmission will return to neutral (stop). This enables the operator to use both hands on the steering wheel or one hand on the wheel and the other operating an attachment like a snow blower, plow, etc.
      The foot pedal is custom cast in Aluminum, uses brass bushings to minimize wear, and it closely matches the OEM Wheel Horse BRAKE pedal commonly found on 8-speed manual transmission tractors. Modifications were done to the pedal to add the reverse pedal and adapt the pedal to the rest of the kit. For the most part, the pedal looks like it was designed and manufactured by Wheel Horse / Toro. Additionally, a grease fitting has been adapted to the pedal to further minimize wear and tear and if the brass bushings ever wear out they are fully replaceable without having to buy a whole new pedal.
      The pedal kit fits the following series tractors with Eaton hydrostatic transmissions: C-1X5, 300, 400, 500.
      My kit can be adapted to older hydrostatic tractors with the Sundstrand transmission, however, you will need to find an updated hydro cam commonly found on ebay. Message me for more information.
      Here is a link where you can download the installation manual: CLICK HERE
      I am selling these kits for $330 shipped to anywhere in the United States. I offer multi order discounts as well. I will also sell to other countries for additional shipping charges to be determined.
      If anyone has any questions please feel free to PM me or post your question here and I will be glad to help. Or you can email me at mattdarling02@hotmail.com.
      Thanks!
      Below are pictures of the complete kit and the pedal installed on the tractor. Some modifications have been made since these pictures were taken. For example, the reverse pedal is now cast in aluminum instead of the steel pedal shown below.
    • Dylan2342
      By Dylan2342
      New here! hello everyone! In a bit of a pickle here. My father owns a 1993 (I think that is the right year) 520H Wheel Horse. I don't commonly work on tractors but it seemed simple enough. the axle snapped on the left side, so it needed a new transmission. My dad bought a used transmission and I went to work changing everything out. The hydraulic pump that the engine's drive belt attaches to went to a different model/year of tractor, so I had to remove that part and swap it in from the old transmission. In the process I lost all of the oil in the pump (I mention this because I wonder if it has to do with my problem I'm having). When I reassembled everything I started the slow process of filling the transmission. I filled it up and started the engine. When moving the lever forward or backward, it had a tiny bit of power for a little bit and then lost power. The transmission wasn't doing anything, anymore. I though maybe that hydraulic pump needed to be primed, so we took the top hydraulic line off of the hydraulic pump right above the drive belt and used a transfer pump to pump some oil into the pump case. This still didn't work. I don't have enough experience with these hydrostatic transmissions to know if we got a bad transmission or if there is something obvious that I am missing when it comes to a transmission swap. I ask for any insight and help please. If you need pictures or any other info, then let me know what you need. Thank you!
