Tvtrader
Belt selection
Tvtrader
I need help in selecting belts for my Wheel Horse tractor.
It is an older model with a changed motor.
It may be a 312.  I know it was purchased before 86.
I took my old belts down to tractor supply and measured them.
So my Question is this.
Should I select a belt smaller to account for stretching and if so how much smaller.
Can I use a regular v-belt to use as a drive belt? (same question for the drive belt)
Its an older tractor but it still runs well.  I try to do what I can to keep it going.
  Thanks
squonk
Belts really don't stretch. The sides wear down and fall into the pulley deeper creating the illusion that the belt is now longer
daveoman1966
Thanks to Mike for clearing a long-lived myth that V-belts stretch.  They don't...unless you are measuring in increments at the molecular level.  Belts simply wear out.
Engine to trans drive belt s/b 5/8 wide ..depends what year. #108501 (81"), 7473 (82), or 78-7100 (82"), respectively.
Engine to deck belt depends on what deck you use...36, 37, 42 or 48" deck ? ? ? ?  Rear or side discharge is also a factor.
The spindle belt on the deck also depends on what deck is in question.
You question is too vague to nail down, especially with other than original engine.
Edited by daveoman1966
shelbyv8
At TSC you want the the blue kelvar drive belt.
Tvtrader
I wasn't looking for a belt #,  just weather or not I should use a slightly smaller belt.  the guy at tractor supply said to use one 2 inches small to account for wear.
He didn't even know how to use the belt gauge so I hesitated to accept his advise.  I did end up getting one 1 inch smaller. (there was one my exact size but out of stock).
My belt measured 85 1/2.  an 85 in belt measured 84 1/2.
I believe I have a 42 in mower deck.
Do I need a special "drive belt" for the engine to deck or will any v belt work?
I will take back the belt I bought.  You guys have saved me the time and trouble of swapping out this belt..... THANKS!
  • Similar Content
    • Bill D
      By Bill D
      Found these at Lowe's.  Same belts as TSC, just different packaging.  The 86" I got was on clearance and is not being stocked anymore.  They had sizes from 87" to 109" in 1/2".  Not a lot of 5/8" belts that would be useful for our tractors.
    • Ifixoldjunk
      By Ifixoldjunk
      I just bought a deck for my 310-8, it’s a 42inch rear discharge, it came with a complete parts tractor, but I need new belts for it. Does anyone know what size belts I need?
    • Tim Fenn
      By Tim Fenn
      I've just acquired a renovated C125 but unfortunately the drive belt got snagged with the mower deck belt (maybe because of incorrect fitment?). It looks like I'm on a steep learning curve! I've been trying to find out which belt to buy as a replacement. The belt I've just taken off is 94 inches but  according to the parts manual I need a Toro belt part number 94 2501 which is 103 inches? The mower deck is a 42in rear eject. It's funny that the Toro belt has 94 2501 as the part number but is 103 inches & I apparently need a 94in belt? Any ideas?
    • CTR
      By CTR
      I have a 312 8 Wheel Horse that i have
      Had for 16 years and thé belts are thé ones that came on thé tractor.I am having problèm finding thé belts. Any hélp would be great.
    • FrankenCub
      By FrankenCub
      I'm new to Wheel Horse, got a fair deal on a 312-8 this week. I have some questions for you pros here, I'm a Cub Cadet junky lol.
      I'm not positive of the year, thinking maybe '84-'85? Unfortunately I didn't think to take a picture of the serial tag and it's at our other property right now. Has a steel frame, not stamped, so I guess it's before Toro got involved? 12hp Kohler Mag, great engine! It also has a 42" rear discharge deck, rough shape but I like the rear discharge. Got it running yesterday and figured we'd give a test workout, went pretty well. Today got into some damp grass that bound everything up, figured that would happen. The PTO clutch started getting hot from slipping and spit out pieces of the facing so I'm sure it wasn't in great shape, and blew the PTO belt.
      Just to get it going again without spending huge cash for top tier belts, where can I get them other than Toro? NAPA maybe?
      If you guys know off hand the belt numbers or sizes for the PTO and the 42" rd deck that would be great. Also going to need a PTO clutch disk if you could point me in the right direction.
      If I get back over to our other property this weekend I'll get some pictures, she's a tad rough but not bad.
