cdsl810 181 #1 Posted July 30, 2015 I'm draining the hydro on the 522xi. The plug is exactly the same as the one on the 520-H (also an Eaton 11). I can't remember if I put a dab of blue on that one when I did a fluid change. My question is: threadlock blue on the plug--yes or no? Share this post Link to post Share on other sites
cleat 7,029 #2 Posted July 30, 2015 I use a little white liquid teflon on mine for good sealing and the ability to get it out again. If it in less than perfect condition I would recommend replacing it as a stripped out plug that cannot be easily removed is a real pain.Cleat 2 Share this post Link to post Share on other sites
cdsl810 181 #3 Posted July 30, 2015 Thanks. The threads are good and were not leaking before. The service manual just says to put it back... but I like the liquid teflon idea Share this post Link to post Share on other sites
rmaynard 15,915 #4 Posted July 30, 2015 If the threads are good, just a little pipe joint compound will do. I use the yellow stuff in a tube that is safe for gas and oil. I don't want to use anything that is going to make that plug harder to get out next time I try. 2 Share this post Link to post Share on other sites
slammer302 2,156 #5 Posted July 30, 2015 ive changed alot of wheel horse trans oils and never put anything on the plug and never have had one leak but i'm sure it would not hurt if you wanted to put some kind of sealing compound on it Share this post Link to post Share on other sites
doc724 925 #6 Posted July 31, 2015 I use the same stuff as Cleat. Works fine and the plug removes easily.Never use Teflon tape, if a piece breaks off inside the trans and floats around to the wrong place, you will not be pleased. 2 Share this post Link to post Share on other sites
prondzy 3,883 #7 Posted August 7, 2015 I don't use it but it won't hurt using loctite. I would use blue only and if your concerned about loctite not releasing the plug, a small propane torch or lighter will work. Loctite "releases" with heat 1 Share this post Link to post Share on other sites
