WHX??
Denny's Free Suburban Work
WHX??
Impromtu bushing driver
worn bushing
curling them out ... go for the worn side and they peel out like tin foil .....thanks for the tip Jake
Starting to work on the the axle flip (Thanks Florida Bob) ....could this be the source of the metal chips??
Should I be worried and look for a new gear about this or run as is??  Keep in mind this Suburban will probalbly not be a worker.... just a show piece
  • Like 5
clip
I'd go ahead and look for a new gear so I could sleep easy at night. No telling what condition the remaining teeth are in, could be similar damage waiting to let loose. Penetrant test might help ease your mind some.
I always fall back on trying to do it right the first time because I don't have time to do it a second time.
WHX??
Agree Clip  - if anyone has a parts tranny I would need a 3530 axle gear ...PM me.
I was thinking about drilling & tapping a new drain hole for a magnetic drain plug????
953 nut
If you are considering reusing the chipped gear I would suggest having it magnafluxed.            :twocents-02cents:
Shynon
worn bushing
Looks like you are having fun, I think you better go out and find another one.:teasing-poke::ROTF:
WHX??
Oh the joy Tom oh the joy.... not quite as fun as your project, I didn't snap off any hooby doos ...yet :teasing-poke:
All in all still alot less expensive & frustrating to work on than chrome horses tho... Gonna have about 500 clams in this girl time Its said & done, shovelhead project has about 6000 clams in it so far and a looong way from done.
Great idea but by the time Id spend finding a place that does it  I'd be further off getting Michigan Jake's.
WHX??
@stevasaurus
Where did I screw up?? Got to work on the tranmission last nite and got it buttoned up. Problem is when I put it in gears it will not turn the axles with turning of the input shaft except for 3rd gear. The shifter detents click into place but nobody is home in reverse, 1st & 2nd. I must have  something backwards & looks like I am going to have to unbutton it and check it out.  It did seem go back together harder than what I would have thought it should. Will go look at your  videos again Steve and see where I screwed up.
Racinbob
It sounds to me that it's coming apart again Jim. I'm thinking you didn't put a key in for the cluster shaft reduction gear. I don't know if that would react like that but it's the only thing I can think of right now.
Now would be a good time to have one put together with threaded rod like I did and Steve in his video. Pop that key out and see what happens :)
WHX??
Yeah could be I didn't take the cluster gears apart when cleaning but I did take the top cluster gear off on the brake side to shoe horn it all back in so I am sure the top key is in but maybe the bottom input side one fell out during install. I was looking at the threaded rod thing and it is together like Steve's. I should have popped the shifter in when the brake side was still off and checked it that way. Thanks
Racinbob
Unfortunately you're probably gonna have to break the right side cover loose to get to that one. Don't feel bad. I had mine together and apart so many times I lost count. :(
WHX??
Well guess I shouldn't have had that extra big ole bowl of dumb f%*# this morning...here was my problem, can you spot it?? Without twisting her neck. ..sorry
  • Like 5
Shynon
Looks like your cluster gear is in backwards.
WHX??
Bingo Tom.....this is what we get for being in a hurry.....the finished tranny, rolls nice....would like to put a nice coat of red on it but fear the wrath of other members. ..:lol::lol:
Sorry about the neck will figure it out o  a tablet...
OK give me crap....I is a WH tranny virgin.....did you do it right the first time!?!?.....get her mind out the gutter. ...?.:lol:
yer mind not hers.......
  • Like 6
Racinbob
Yupper dupper. Flat out backwards I wouldn't have thought you could get her back together like that. No crap slinging from me. You should see some of my moves. :D You done good! :handgestures-thumbupright:
AMC RULES
Looks good to go now...  :handgestures-thumbupright:
I would paint it only if you're redoing the whole tractor.
WHX??
Would love a redo ... with all polished stainless allen head hardware and decals and duals and lots of bling bling and ...... somebody stop me...... oh well next one....
Hats off to Michigan Jake for the parts.
I did add a non oem magnetic drain plug to it.
stevasaurus
Sorry, I just saw this and it looks like I missed all the fun.  I can't believe you got that cluster gear in upside down. :)  Great pictures though.  :handgestures-thumbupright:
For some reason I am not getting a notification when someone does the @stevasaurus.
Edited by stevasaurus
WHX??
Just like Steve....always late to the party!!!:lol:
AMC RULES
Can't be late... :party:
when Dino is the party.
WHX??
Figured I might as well udate this thread altho ain't much to update as one doesn't get much done when one's arm is in a sling. Thats ok as long as it's ready for PA this summer--- finnished tranny oiled up to @Shynons specifcations.
WHX??
After forcing the boy to child labor (bribing him with money) at the parts cleaner got to look at these. Holes in the axle are quite oblonged and spindles aren't the best. Somewher along the years someone must have not liked the grease gun. Notice the zerk missing out of one side. The options the way I see it unless you guys have other ideas is to
A ) Bore them out and install bronze bushings or
B ) Grease the snot out of them and run as is
Also what to do about this drag link??
Dennys502
Looking good Jim. She will be a beauty when you get her all painted and buffed out. :)  I'm glad I didn't restore it as it looks like it was used and abused. You're doing a good job - keep up the good work.
WHX??
FINALLY .....a roller!!!
The spindle holes in the front end were quite oblonged  so I managed to get some bushings installed so it tightened up fairly well. Spindles were pretty worn too but that would have been real  expensive machining so will run as is.
  • Like 5
WHX??
  • Like 5
Shynon
Looking good. And here I thought you shelved this project for a painted one :ychain:
  • Similar Content
    • wh315-8
      By wh315-8
      The RJ58 was the big hit for spectators this year at my local festivals here in Carroll County OH.
      the children loved getting their pictures sitting on it, then they discovered the bicycle horn under the steering wheel. It’s always a joy even in parades. Just love showing off part of my collection every year and hearing all the stories from those that had WH in their lives at one time. Can hardly wait to get to retirement so I can get some of my other models back to their glory in working order and be able to attend other shows/festivals throughout the year. My fellow tractor enthusiasts always know when a spectacular starts asking about WH, they point in my direction. I study up on the history of the different models and always intrigue those that didn’t know much about how WH came to be. This website is one place that has helped me learn so much about the WH history and I thank you for sharing your knowledge that I am able to pass on to keep WH alive and well.
    • Vaughan32850
      By Vaughan32850
      Has anyone got a WT-30 tiller they can send pictures if pleas? It’s the one fitted with a K91 engine for RJ models.
      Many thanks
    • Jennifer
      By Jennifer
      Husband wants some advice… lol.  So we did an engine swap today on two suburbans because we could not get the one engine to spark all the time to get it running!  The engine ran last year before parking for the winter sleep…. Points were changed out for new the engine was cleaned to make good contact has new spark plug new coil condenser we even switched out the fly wheel today thinking maybe the magnet was weak…. Advice???   It would where are you out yanking on the recoil five or so times and maybe only get the points to fire twice if you’re lucky..  checked the gap and pull again… same thing over and over!  Thanks in advance!
    • Jeff-C175
      By Jeff-C175
      Detailed wiring from the Demystification Guide #492-4509
      4 pages 1.4MB Color
      p7-67 to p7-70
      Onan powered
      1989 416-8 model 31-16O801
    • Jennifer
      By Jennifer
      Well my husband got new grownup toys!  Lol. Just wanted to post them on here to share!  Sure most seen for sale but they arrived yesterday at our back door glad we found them before it rained again!  Not sure why delivery person made the effort to go to the back of the house…. 🤔🤯
