Similar Content
By Team70R
Still can't get my 42" SD to cut even. It appears the right side of the deck is hanging lower than the left side at the highest 2 levels. And out of the 3 front deck wheels only the right one touches the ground when im parked on the concrete. Which hole should the lift rod be in?
By mikekot3
I am replacing with new spindle assemblies of my model 78345 mower deck. I am unable to find in the manual section what the torque needed to preload the pulley to spindle
bearings under the protective covers on top of the mower deck.
I found the torque required for the blades to be 80-120 lb ft in one of the manuals here.
Please advise or tell me which manual it is found in.
Thank you,
Mike
By dlaw90
I'm looking to add a mulching blade to my 42" Rear Discharge (Model 78350). I would like to stack the mulching blade above the regular blade like this (picture is not mine):
I can't find a mulching bladewith the same specs as the Toro blade (Part # 106635).
Length = 14 1/2"
Width = 2"
C.H. Diameter = 3/4"
Thickness = 0.2040"
The Oregon 90-643 G3 Gator blade is close.
Length = 13 7/8"
Width = 2.5"
Thickness = 0.203"
Will the difference in blade length cause any problems? It seems like everything would still be balanced on the spindle and the Toro blade would still allow a full 42" cutting path. Am I missing anything? I have not verified that there is enough spindle length to accept both blades, but it appears this hasn't been an issue for others.
By Zeke98
Hi All,
I'm new to the wheel horse forum. I inherited my Grandfather's 416-H. The deck is showing some holes from rust. Would you suggest I have the deck welded or try to replace the deck with one in better shape? You can see some metal plates in the attached photos. These were a quick fix. It's time for a real one!
I've also included the model number of the deck. I'd appreciate any suggestions about what other model numbers would be compatible with my tractor.
Thanks.
