HorseHead1089
An Advantage on Cub Cadet Manual Trans...
HorseHead1089
A cool thing in case the pure red junkies didn't know. The cub shift pattern allows for aftermarket Knobs, also matches the 3rd gear speed and feel of the shifter clunk.
3_speed.thumb.jpg.2811d8237e2487f4e259ed P.S. Cubs are red at heart...International Harvester is red.
baerpath
If only they weren't so prone to breaking
HorseHead1089
what all is the weak link in them. i have to replace some bushings and some cleaning to my transmission so maybe if its easy to get to they may have a stronger part to replace it.
baerpath
weak part is the stock carrier, you can upgrade to a two piece carrier, or a dart one.  We have broke the input shaft and the forks  Seem more cubs break their axles than WH's  My son could change a cub rear out in 15 minutes. We used to pull with JD's Cubs and WH now only WH in the stock classes
