OneWithWaves
312-8 Won't start; dim seat switch light
OneWithWaves
Hello everyone,
Sorry to make an account and post for help right away, but I plan on sticking around for a while. Anyway, I'm having a hard time getting my 312-8 tractor to start. It's got a Kohler Magnum 12 engine and the ID under the seat is 2112K806 (space) 37223. A few weeks ago it decided it didn't want to start; when the key was turned to the run position, the seat switch light was dim or flickering very faintly. I assumed the switch was dead, as it didn't have a distinct "click" when it was pressed any more and the tractor is approaching about 30 years of age.
I just got a replacement seat switch from Toro and installed it, but the tractor still refuses to start. The first few times, the seat switch appeared to be working correctly but the tractor insisted the clutch wasn't pushed in, according to the dash lights. I came back a few minutes later and the tractor still refuses to start, although now the seat switch light is behaving as it did before. If I leave the key in the run position and get off the seat, the light works correctly and lights up brightly and solidly, but sitting back down causes it to pulse and light dimly again. I've tried engaging and disengaging the PTO clutch, which the dash reports correctly, as well as the regular clutch, which also seems to respond correctly now.
I'm hoping you fine folks might be able to help me, as the tractor is going to get sold if I don't get it running and it's quite important to me. Any and all help is greatly appreciated, and I thank you in advance for your help!
Don1977
buckrancher
check the motor oil level
there are 3 safety switch's that will keep the tractors from starting if the key switch is good
PTO lever switch
clutch pedal depress switch
oil level switch
also check 25amp fuse
Brian
OneWithWaves
Thanks for the advice, Brian!
This probably comes off as a stupid question, but where would I find the 25 amp fuse? My original manuals are long lost by the previous owner and the only fuse I see is one that's clipped to the battery tray; it looks like a regular automotive fuse and it looks good to me. I believe the oil level should be fine but I'm sure it needs to be changed very badly - where would I find the drain for the oil, and what viscosity should I replace it with?
gwest_ca
Here is a good detailed wiring diagram. Each circuit has it's own diagram.
http://www.wheelhorseforum.com/files/file/1862-tractor-1989-312-8-wiring-detailed-492-4509pdf/
Is the problem the starter won't engage and run to crank the motor over or
No ignition so motor won't run.
There are 2 pto switches.
One controls the starter along with the clutch pedal switch and the low oil relay.
The 2nd pto switch controls the ignition along with the seat switch.
There is a chance you have bad grounds. May be worth while to remove and clean them up.
Garry
Here is the 1989 operator manual
http://www.wheelhorseforum.com/files/file/2021-tractor-1989-300-series-8-speed-om-wiringpdf/
Kohler operator manual
http://www.wheelhorseforum.com/files/file/4107-engine-kohler-magnum-m-8-m12-m16-om-tp-2200-fpdf/
Garry
OneWithWaves
Thanks for the diagrams and advice, Garry!
I think you're probably right about the grounds being bad. I just got the tractor to start and it ran great - once it was running, the seat switch was working perfectly, killing the engine when I stood up with the PTO clutch engaged, but once I parked it again and attempted to start it, it went back to looking like the circuit is bad. I can see the wires coming from the seat switch and know the black one is the ground, but I can't find where it is grounded to the chassis as the cluster disappears under the instrument panel. I was wondering if anyone knows where the seat switch is grounded on this model or has an idea based on other models as I'm at a loss for where to look.
I also forgot to add - the ignition works fine; my issue is the tractor refusing to run the starter motor when I turn the key to the start position.
Edited by OneWithWaves
buckrancher
use a jumper wire from the + battery terminal to the 1/4 blade terminal on the starter solenoid  to check if the solenoid is good you can also jump a cross the large terminals on the starter solenoid
this should make the starter motor run to check that
Brian
OneWithWaves
Hi everyone,
Sorry for disappearing for a week but I haven't had the opportunity to put some more work into this tractor until today. It took me an embarrassingly long time to find the seat switch ground, which was bundled with many of the other grounds on a terminal connecting to the battery's ground. I took these grounds apart and cleaned up the connectors with some light sandpaper; the years of service had definitely done a number on some of them. I put the whole thing back together and got the starter to crank for one attempt, which got me excited (the tractor starts reliably, but only if it gets about three shots with the starter motor), but then the symptoms from the beginning of this thread cropped up again. Now, I'm not sure if maybe I missed another ground wire somewhere or if it could be a problem with the solenoid, as Brian's mentioned. It just seems strange that the dim seat switch light could be a symptom of a bad solenoid. Anyway, I found it on the tractor but it seems a little different than most of the solenoids I've seen (and I'll admit I haven't seen too many before). It looks like it only has two terminals and a ground, and from my understanding there are generally 3 or 4 terminals with a ground. I've included a picture of this solenoid - would I still test this one as Brian suggested or is there something different about this one?
Thanks for all your help this far!
IMG_20150730_120358.thumb.jpg.899d3f38ac
PS When you look at the photo, notice the ground isn't actually grounded to the frame of the tractor, but a small ground wire connects it to the bundle of grounds I mentioned earlier in this post.
  • Similar Content
    • 953 nut
      By 953 nut
      I have a few basic electrical system diagrams that are helpful in understanding how the wiring system works. They are not specific to any particular tractor and do not include safety switches. All use the 5 post ignition switches 103-991 for Magneto and 103-990 for Battery Ignition. I failed to include fuses in the Starter Generator drawing, this is an over-site and I would encourage fuses be used as shown in the other two drawings.
      Hope this is helpful.
      Magneto Ignition system with electric start and solenoid.
      Battery powered ignition system with points, condenser, solenoid and electric start.
      Battery powered ignition with solenoid, points, condenser, Starter Generator and a mechanical voltage regulator.
      We have uncovered a shortcoming in the factory  wiring diagrams for S/G battery ignition systems with a four terminal voltage regulator. The wire from the regulator "Gen" terminal to the S/G  "A" terminal was omitted. This drawing should clear that up.
    • Gingerbread
      By Gingerbread
      I’m new to this and not sure if I’m doing this right, But I have a 211-4 with a Briggs 11hp and the thing was sold in my town years ago when it was new. it was my grandfathers till now so it’s a nice piece of history. and it has some electrical problems I can’t figure out, It blows the 15Amp fuse as soon as you turn the key, it all started after the I had to replace the the ignition switch. And now it just blows the fuse. I messed with it when it happened but I have been away in the service for about two years, but now I’m on leave and want to fix my pride and joy but don’t know if my wires are all in the right spot. And my brother actually hooked the battery up backwards by accident for a few seconds while I was away so don’t know if that did anything. So any helpful suggestions or pictures for an example to look at. Thanks
    • illinibrew
      By illinibrew
      I have been into garden tractors for a few years.  Wanted to learn about small engines and buying an old sear suburban was cheaper than the class at the local community college.  Just got a 1980 C85 (with a johnny bucket on it).
    • richm1386
      By richm1386
      Quick story and a couple of questions concerning replacing the ignition coil on my '89 416-8 with Onan P216 engine.
      So I got this old tractor from my Dad when he replaced it and it was running okay until a few weeks ago. Was picking up sticks and hauling them out to the wood pile when I idled down the tractor and then it stalled out (which happens all the time.) I tried starting again and it would not turn over. The starter would go and go but no ignition. I spent a lot of time on these forums and found some really good info including the service manual. I used that diagnose the problem and figured out the coil was bad. I ordered a new off brand coil and condenser from Amazon for $40 swapped them in last night and it fired almost immediately. Plus since I had taken the shroud off and disconnected the throttle cable it was idling well at very low throttle. I've still got to reassemble everything properly but it seems like the coil was the culprit.
      That said I've got a couple questions.
      1. Anybody have any luck with non-Onan coils?The one I got from Amazon seems well made but it is literally some no name part. I figured for $40 it was worth a shot.
      2. Does it matter which spark plug attaches to which plug on the coil? I forgot to take a photo before I disassembled.
      3. Could a failing coil cause very hard starts and stalling at low idle? I'm asking because as I said above the tractor has been very hard to start for years. Almost always needed to choke it. It would also stall out if you idled down nearly every time. Just the brief testing with the new coil that I've done, both of these issues seem much better. Also I used my Dad's replacement (early '90s 416-h with same engine) for this tractor while working on mine and it started and idled very easily. It looks like it might have a replacement coil as well. Just wondering.
      Thanks all.
    • tntatro
      By tntatro
      The stator and flywheel on this engine are different than others I have worked on so far. The stator is smaller in diameter and has a wire that runs out to a part that looks like an ignition coil but has no plug wire. I am wondering what it is and how do I wire it?
      I'm not 100% positive that I put it back in the same spot it came but I think I did. I gapped it at .020" from the bump that sticks out on the flywheel, it is magnetized.
