edwroy
Hi all, I am interested in adding a set of rear remotes to my 520H. Has anyone done this? Would like some thoughts on how they new lines would connect to current lines.
Thanks,
Edwroy
bmsgaffer
Its on my TO-DO list for adding a rear lift cyl and ports for hydraulic swiveling of the snow blade. The current lift valve is open center so you should just be able to put it anywhere on the charge pump auxiliary output line (the loop that connects to the existing lift valve).
Things you may already know:
Just be sure whatever valve you add is open center and has a pressure release built in that you can set around 700psi. (easiest to just use another valve from any eaton-powered horse)
Also keep in mind that the charge pump will be a bit less than 1.5GPM, max 700psi and the transaxle reservoir is fairly small so be cautious of the fluid level when filling them on the first run.
