kudzu3 323 #1 Posted July 22, 2015 Do you shut off the gasoline from the tank every time you use the tractor or just when it is going to set a long time without use? Share this post Link to post Share on other sites
KC9KAS 4,741 #2 Posted July 22, 2015 Depends on the tractor....some have a fuel leak, so I shut them off! Share this post Link to post Share on other sites
groundhog47 347 #3 Posted July 23, 2015 I shut mine off every time on both I use as it seems to stop the intermittent needle stick situation (which may clear now that have started using ethanol free). I still smell gas when get the hood open but see no dripping when sits awhile before use. Both tanks have the "baffle" piece in lid. Till I run it down I'll still turn the valve off and run a bit before shut down to relax needle on seat. 1 Share this post Link to post Share on other sites
